There is no Morph manager for Mac that I know of .. If you fnd it please let me know .. S I think if you save the morph target (post patch which I am attempting for the 4th time to download) it will export the head obj without the eyes and stuff .. What that does is that it only affects things that are different from the original obj file. Don't export te head because unless the person's figure is exactly the same position as yours it won't work well ... even then there is a cahnce it will be funky Good luck and thanks S
-Dial only the morph you want to export to 1 -Export .obj -When hierarchy list comes up uncheck universe, then check the part you want to export. -When the options box comes up uncheck all boxes but the one that mentions world cordinates -You have a morph. Now this morph will probabbly be huge! because it has alot of .obj code that poser dosen't need. You can open this .obj file in a text editor and delete all lines except for the ones that start with a "v" (these are only ones poser stores in the .cr2 -Trav Awsome morphs BTW!
