Thu, Feb 20, 5:28 AM CST
Forum Moderators: RedPhantom
Subject: My Millie morphs
Ian Porter ( ) posted Mon, 27 March 2000 at 1:18 PM ยท edited Mon, 17 February 2025 at 3:15 PM
Online Now!
Having read through some other posts here I'm not sure about posting morphs for Victoria, ie: is it Ok to post them, and if in what format? For the moment I have removed the morphs. Maybe Trav can advise on what will be an acceptable format? I hope that Zygote will allow posting of morphs for Millie as that should encourage more people to buy her.
steveshanks ( ) posted Mon, 27 March 2000 at 2:44 PM
just post a cr2 you can't use that without the obj...Steve
Ian Porter ( ) posted Mon, 27 March 2000 at 2:59 PM
Online Now!
Steve, thanks for that. Is posting of a cr2 Ok? it is still part of the 'package'. The cr2 for Victoria is about 2.8Mb which is a big download for a small morph, still if that's the rules then fair enough. Would I need to post seperate cr2's for Victoria, and Victoria with texture map.. ie 2x 2.8Mb ? Ian
steveshanks ( ) posted Mon, 27 March 2000 at 3:09 PM
well a cr2 is definetly ok copyright wize i checked when i posted NYW ones ..its a bummer about the file size you could try using mover to encde the obj see if thats smaller....Steve
JeffH ( ) posted Mon, 27 March 2000 at 7:54 PM
Post a .PCF version of the MT OBJ file encoded with OBJaction Mover using the Millie OBJ as the seed. -JH.
picnic ( ) posted Mon, 27 March 2000 at 8:19 PM
How does Traveler do it? I don't have a clue, but have almost all his morphs and they are easy to work with--unzip and I move them to my morph folder--they are .obj's as I recall, though. Diane B
JeffH ( ) posted Tue, 28 March 2000 at 4:21 AM
Trav removes the Texture, Normals and Facet data so that all is left is the Vertex data. I can do this easily in RayDream, but I'm not sure what he uses. -JH.
Ian Porter ( ) posted Tue, 28 March 2000 at 12:03 PM
Online Now!
All, Thanks for the suggestions. I think there's a post from Traveler somewhere here which says that he's still waiting for advice from Zygote on the cr2 or vertices only methods. I've downloaded the current version of Mover (thanks Maz). I tried using good old Wordpad to edit out everything but the vertices, and the resulting file still works as an MT. So maybe it's that simple. If Zygote say cr2 only, would it be possible to create a new 'micro' cr2 for Millie, from a basic heirarchy file, with just enough in it to select body parts and apply morphs to them? The resulting mini cr2's could then be posted, and morph manager used to 'extract' included morph target. Hmmm, maybe way overcomplicated...I'll look into the suggested solutions posted here. Cheers Ian
picnic ( ) posted Tue, 28 March 2000 at 12:10 PM
Ian, check out the morphs already posted in FS. I don't know diddly about this, but I'm not using Objacter to open these. Diane B
Ian Porter ( ) posted Tue, 28 March 2000 at 1:19 PM
Online Now!
Diane, I know there are morphs in FS. which don't need Objacter. I guess if enough people post enough bodyparts someone could build themselves a free Victoria like Frankenstein's monster. (Hell of a long wait for the fingers and toes though.. :)). If Zygote object, (no pun intended) I don't want to be on the wrong end of their legal dept. Maybe I'm being overcautious. Just because I'm paranoid it doesn't mean they're not out to get me........;} Cheers Ian
