Fri, Jan 10, 12:02 AM CST
Subject: Raytraced shadows and reflections.
nerd ( ) posted Sat, 05 October 2002 at 8:47 PM · edited Thu, 09 January 2025 at 3:50 PM
Forum Moderator
Could somebody check this I believe that raytraced shadows don't show in mirrors. This uses 2 lights both setup with raytraced shadows, the "Mirror" has the reflection node tied to alt Diffuse. Don't wanna pester CL till I'm sure I'm doing this right.
Little_Dragon ( ) posted Sat, 05 October 2002 at 9:17 PM
Raytraced shadows appear in reflections. At least on my system. I haven't installed the patch yet, so my mileage may vary.
On the left: shadowmapped shadows.
On the right: raytraced shadows.
nerd ( ) posted Sat, 05 October 2002 at 9:52 PM
Forum Moderator
Well, I can't seem to make them work with SP1b. I'll fool with this more latter. ngsmall02.gif
Lurking in the Shadows...
EricofSD ( ) posted Sat, 05 October 2002 at 10:08 PM
It looks to me like your mirror object is not casting a solid shadow so the ground plane shows up. But the wall behind the mirror does show a full shadow. So maybe some tweaking on the ground plane? or check your lighting to make sure you dont' have a light slighly behind the mirror object that is shining down. Oh, wait, I see the problem. The right side of your mirror cube (right to the mirror not your right) is reflective so its reflecting the ground plane. Instead of a cube mirror, make a 2d face mirror.
lalverson ( ) posted Sat, 05 October 2002 at 10:35 PM
as fate would have it I'm attempting an image where the stage is set in a similar way. currently it is still rendering. but once it's done. I'll check
nerd ( ) posted Sat, 05 October 2002 at 10:37 PM
Forum Moderator
OK, started all over. One light, Raytraced Shadows. Production Render. Would somebody running the patch please try this for confirmation.
depakotez ( ) posted Sat, 05 October 2002 at 10:46 PM
RayTraced shadows aren't showing on mine either. In production or draft settings. I'm only using the reflection node in the alternate diffuse with a quality of .2 and softness of 0. Depth shadows work just fine. I'm running patch "a" with the pref updates on a: P4 1.9 Ghz 756 MB SDRam GForce 2 MX
nerd ( ) posted Sat, 05 October 2002 at 10:50 PM
Forum Moderator
OK, I guess that makes it a real bug. (I thought I was loosin' t for a while there) I'll mail CL with this thread. Maybe SP2 will fix this. ngsmall02.gif
Just lookin' for some shade.
Crescent ( ) posted Sat, 05 October 2002 at 11:09 PM
The shadows are showing on mine, but they're screwing up the actual reflections - giving them jagged edges. I posted about this a few threads down.
lalverson ( ) posted Sat, 05 October 2002 at 11:33 PM
The lights washed out most of the shadow, but it does look like they are there
volfin ( ) posted Sun, 06 October 2002 at 1:18 AM
Top picture is regular shadows, bottom is raytraced shadows. I notice that the hilights on the ball disappear in the raytraced version as well as the shadows. Pretty odd.
volfin ( ) posted Sun, 06 October 2002 at 1:19 AM
oh, and I have the version A patch I think. I downloaded the patch split into two parts.
nerd ( ) posted Sun, 06 October 2002 at 1:40 AM
Forum Moderator
lalverson, Were thaose Depth Mapped shadows? I just got a message back from CL support. They were able to duplicate it and it's on the to fix list. Volfin, I've noticed that raytrace light will not penetrate a prop even if it's "Cast Shadows" is turned off. That may explain the missing highlight. Sitll probably not right. You may want to let CL know and see what they say. ngsmall02.gif
thgeisel ( ) posted Sun, 06 October 2002 at 2:03 AM
think the raytraycing got much better and faster,but it has not the quality bryce raytraycer has. maybe i do some comparing images with one scene rendered in p5 with ff and another with the same setup in bryce. in bryce lights can penetrade glas and its focussed as if you have a lens.
ARCHITECT ( ) posted Sun, 06 October 2002 at 3:02 AM
aaarghhh... I NEVER get ANY nice reflections... I just can't figure out the lights and the best settings/materials for a mirror to reflect more than something like a "ghost" of the character in front of the mirror. Is there a tutorial how to make reflections in P5?
thgeisel ( ) posted Sun, 06 October 2002 at 3:27 AM
only a short one i did in bryce 4.left sphere with a glas mat ,right sphere a mirror mat. res 720x540 rendertime 8 seconds ( athlon 2000) And architect : its very hard to get a good reflecting mat and it seems to depend much from the light you use.
aleks ( ) posted Sun, 06 October 2002 at 3:51 AM
@ lalverson and crescent: i think that those stripes in the mirror come from the light that stands almost on the same plane as reflecting object (plane) AND the reflective object is set to cast shadows. i guess that moving the light a bit from the reflective plane (so the shadows aren't parallel to it) might help.
nerd ( ) posted Sun, 06 October 2002 at 11:30 AM
Forum Moderator
ARCHITECT, Attach the reflection node to the Alternte Diffuse. Set all the colors to black except for the Alt Diffuse, set it white. That's all. ngsmall02.gif
thgeisel ( ) posted Sun, 06 October 2002 at 11:32 AM
nerd: i alwqays attach the reflectionnodes to the reflectcolor.Why do you use the alternate diffuse?
Crescent ( ) posted Sun, 06 October 2002 at 11:33 AM
No shadow vs. shadow My lights weren't parallel to the ground plane. I didn't have stripes, I had roughness on the edges of the reflected figures. I can see the jaggies in lalversion's picture as well, especially on the male figure's reflection. (Look at the shoulder, for example.)
nerd ( ) posted Sun, 06 October 2002 at 11:44 AM
Forum Moderator
Crescent, send that to CL maybe they can figure out what is going on there. It may be some sort of interference between the Raytraced reflection and a displacement shadow. (Has to be a displacement shadow, as it's showing in a reflection. OR What channel do you have the reflect node tied to? Try hooking it to only the alt diffuse. See if it still does it. thgeisel, You will get a more pure mirror relfection with the reflect shader node attached to the alt diffuse. The reflect channel will make it look washed out. I dunno why but that's the way it seems to work best. If you want a colored morror add a little color the the alt diffuse channel. ngsmall02.gif
thgeisel ( ) posted Sun, 06 October 2002 at 12:12 PM
nerd : thanks ill give it a try
volfin ( ) posted Sun, 06 October 2002 at 12:13 PM
Crescent, I think the jagginess you are seeing may be related to the minimum shading rate setting on the render options menu. If you have it set above 2, you are going to get a render like that. The higher the number, the less precise the image. The manual states the opposite, and I suspect this is leading many astray.
