Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 8:20 am)
yes, but it also stopped before i did the patch. I tried to make the AsShanim-Cloth dynamic. Import of the obj, belt as constrained or choreographed, so that only the loin back and front is dynamic. i thought this should be a rather easy thing, easy geometry and not many vertices, but in frame 19 calculation decided to meditate in an endless loop or something like this. Maybe wrong geometrie, i left all the settings in factory state for this test, the information about this is a bit small in the manual. So i'm waiting for useful tutorials or the next patch :-)
I just found the bug it was the cloth density scaled at 1.0 in cloth room. After scaling it to 0.0001, it worked good and the cloth became very firm. I think 1.0 make a prop very sloggy and hard for P5 to calculate because of the polygons fracturing with other polygons in slime-like behavior. Waldoo
Dynamic clothing simulation calculate processor stopped working at about 11th frame. It happened after I patched SP1 update. Did any of you had this similiar problem? Waldoo
