uknight, I got the same problem when I tried to render. I think something is wrong with the AVI rendering option. The individual frames will render, however. So simply: (1) change the "sequence type" option in the "make movie" window from AVI to image files. (2) Next, render the image files(either jpg, png, bmp,tiff, etc.) to a folder of your choice. (3) use an AVI animation creation program such as AnimationShop (there are lots and a few free ones also) to collect and sequence the still images into your own AVI file. A p.i.t.a. glitch, but it's not to hard to find a work around. I hope CL addresses this soon. Btw, did you report this problem to CL? I hope this helps. --lb
Attached Link: http://pws.prserv.net/usinet.rance01/rqsv.htm
The problem with AVI animations also happened to me BEFORE the patch. I haven't tried to render an AVI since but use the image files work around mentioned above. I haven't tried to render to AVI since the patch (sounds like I quit smoking or something) because I didn't want to waste the render time. I will try to do a short animation today sometime to test Poser 5. I've always had problems with Poser's AVI files anyway. The format was never quite right. I rarely render animations with compression as I will want to edit pieces together later. I've a couple of video applications which simply do not like Poser animations. The one I've had the most luck with is VideoWave. I just don't really care for that interface much.Thanks for the tips/info guys. I just wanted to check that it wasn't me doing something wrong. I'll send of a bug report to CL. BTW... Just out of interest it seems some people have this problem and some don't - I'm using Windows XP pro with SP1 installed, 512Mb RAM, Atlon 1.2Ghz Thunderbird processor - the system was home built. Dunno if my setup makes any difference.
Attached Link: "Rock 'em Sock 'em Robots Animation"
It works fine for me (not that my animations are all that great). Could it be the CODEC you are using?I tend to use DIVX but I know I've used the Microsoft one too.
I have a primitive animation at the 3D Fight Club (a great site for modelers looking to blow off some steam and have a good time). There's a link to it on their main page (probably until Monday... after that you could find it by going into their forum under the weekly scene animation topic... Rocky Animation).
Hi, I've been trying to render my animation as an AVI file in P5 using the Firefly renderer but all I get is a blank grey (background) picture (ie no props, figures, ground, NOTHING)! If I render the same scene using the P4 renderer it works fine. The raytracing toggle etc... seem to have no effect - still a blank grey picture! Rendering just a single frame from the animation either into the document window or into a new window using firefly works fine. I've installed the SP1 - did it do this before the patch? Am I missing something obvious? Any help VERY much appreciated.
