Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 10:48 am)
I haven't seen this myself. Do you mean in the Materials room, you see only the names of the materials, but not the picture? Or, in the room itself you don't see the preview at the bottom of the main node? If the latter, check to make sure the eye in the upper right corner of the main node is showing it open. If the eye is closed, it turns off the preview. I had this happen to me after I accidently clicked on the eye, and it took me a little bit to realize what had happened.
After the update my material's pallete looks exactly the same as yours EXCEPT the texture preview/thumbnail at the bottom does not show. All I get is a black square. Id doesn't matter what kind of material I load, Judy's texture, a brick texture, or any of my custom made textures for my characters. The textures on the subsequent nodes also don't show (such as bump, reflection map or anything else). Thanks for looking in to this! Jay
Very strange! I'm sorry, but I am out of ideas. I was kind of hoping that some setting got changed and that it might be an easy fix. But I certainly don't see anything that doesn't look right. I tried everything I could to get mine to do this, but I wasn't able to. You might want to email CL at bugs@curiouslabs.com, and include this screen shot. Hopefully, someone will see this that can be more help than me.
Has anyone experienced this? After I run the updater the thumbnail preview on the texture pallete no longer displays. Can that be fixed? Thanks for any input. Jay
