Attached Link: http://perso.club-internet.fr/lemog/lemog_textures/metal_toles.htm
I've made metal texture tests a while ago. Metal is generally not as smooth as the default Bryce ones. I would use a brushed pewter textures with a bitmap texture used as bump and maybe diffusion/diffuse color map. Also reduce reflexion if you want the Check out the attached site for tileable metal textures. I've had good results with these.Eh, the third time is the charm. This answer hit the bit bucket twice now. Yes, I have to shorten the blade, because it's supposed to be a longsword, not a two-hander. Thanks for the textures. There's irony in the fact that I used one of the metal textures from there for the guard. :-) I found something. What does it mean "acier bross, if you know?
-- erlik
In regards to your textures, I think they have some good potential. I am wondering if I am seeing the hilt right though. It looks to me as if it's made out of plastic or something. If that's the intent, excellent. As for the blade, usually the ones I've seen are more polished and act more as mirrors getting their colors from their surroundings rather than themselves. Their edges are more the brushed metal look due to the sharpening they go through... depending on how it's sharpened. Just a thought to help out.
Attached Link: http://www.swordforum.com/wallpapers/swordofprayer-800.jpg
Well, now you can see the original. It appears I'm not that close as I thought. The blade doesn't need shortening (much), but it does have a shinier texture and a longer groove. I'm reworking it completely. And the handle has even more plastic texture than mine. :-) I used a combination of Bryce plankwood texture and a leather photo. What makes it shiny is Ambient colour. I tried putting black, but you can't see the texture then. Thanks for the suggestions, everybody. BTW, if you're interested, the inscription on the guard comes from Psalm 16 from the Bible. I simply like such double meanings on weapons. :-)-- erlik
Attached Link: http://216.245.165.123/cgi-bin/www11651.storefront
Also check out Atlanta Cutlery Museum Replicas (link), and www.budkww.com, for reference in swords, daggers, axes,chainmail, etc. ZhannBryce Forum Coordinator....
-- erlik
