Forum Moderators: RedPhantom
I assume you're using the Millennium Figures.
Irises:
The Millennium figures have a transparent covering over the eyes. Cartoon w/Lines doesn't do transparency, so the covering becomes opaque, and you end up with those Little Orphan Annie eyeballs.
One solution is to morph the transparent covering out of the way, to reveal the eyes. Mazak has such morphs for the Millennium figures on his website.
An alternative solution is to select each eye, then go to the Display menu and change their display mode from cartoon to textured. That way, you can have a cartoon-shaded scene (Document Style) and figure, and textured eyes.
Display menu --> Element Style --> Texture Shaded
This isn't optimal, however, since you'll have those white dots indicating the transparent layer.
Eyelashes:
Most eyelashes are done with transmaps, so it isn't possible in the cartoon display modes.
However, you can hide the original eyelashes by morphing them, then replace them with props or conforming figures that have actual modeled hair follicles. FishNose and OpticalSingenoid have such items in Free Stuff for Victoria and Stephanie.
If you use the Real Lashes, I recommend that you use the Display menu trick mentioned earlier to set them to Cartoon mode (not Cartoon w/Lines). If you use Cartoon w/Lines on the Real Lashes, you get a black outline around each follicle, and the result looks like heavy mascara.
Poser 4 Question, Im not with the times yet lol In this display setting is there any way possible for the iris to be shown and the eyelashes to have transparency? Thankyou James
