heyas; the fastest way would be to do the magnetizing, then re-save the clothing to the library. then, the next time you load the clothing, it will have the magnets on it. you should memorize all the magnet parts (base, mag, zone) for each magnet before you save. just to avoid potential problems in the future. memorizing is on the edit menu (i think). you can't save the magnets with a pose. well, technically, you can save the posing information of the magnets, but since you are not saving magnets with the clothing, there's nothing to apply the magnet pose to, unless you re-add magnets each time you load the clothing. you can't spawn a full body morph that will use magnet settings. the fbm will only use morphs. you could turn the magnets into morphs for each body part they are affecting, set the new morphs to 1 and spawn a full body morph, if you wanted to. then you could delete the magnets. but remember to save your clothing back to the library again to save the new changes.
hello ! I m conforming a cloth to vicky, and my problem is this : The cloth, when "Conformed to" Vicky doesn t snap to her the way i want, so i add magnets, change X and Z and all that. Now it fits perfectly. I want to find a way to save those changes so that when i open this cloth again I can "Conform to" Vicky and then snap it perfectly by appliyng the home made changes. What I tried : - Saving a Pose, selecting Universe and Cloth as sub subject. It won t work. I open the cloth, conform it to vicky, apply the pose to the cloth, and nothing happens. - creating a full body morph. Same things happens, if I conform the cloth to vicky the changes won t hold. Anyone can help with this ? please ? :) Jef
