billy-t and _dodger have jackets matching that description in the Renderosity Marketplace. ronmolina has a jacket collection in there also, although it might not be quite what you have in mind.
Ghastley has a free open jacket for Michael, but it might be too long for your needs.
Either I'm stupid, or there is nothing like the things I'm looking out there! The problem: I'm looking for a special type of jackets to complete an outfit for several images: Open, short jackets for both Mike 2 and Vicky 2. The length should be down to the "beltline", the style should be like an avarage, normal leatherjacket. Textures don't matter, as I would have to use my own anyway, but it would be good if they were both in the same style, they could have pockets (a plus), but that is not primary. They should be conforming, if posible. Using transmaps to make them shorter would not be a solution, as at least one image I have in mind will result in a high polycount, most of the work will also be done in another app, so transmaps might cause problems. I'm using Poser 4 on a PC. Does anyone know where I can find such objects?
