Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
I used a pose that was done for eve, then adjusted the lights. The hair is done in Painter 6 using pattern pen with the size turned down on both the pattern and the pen. Then you just layer in different strokes changing the layer characteristics, overlay, soft light, and transparancy until you get the look you like. I also discovered that it is better to use wiggly lines cause hairs are not always straight they are all over the place. The face is the one that comes with the model. This one I also diddled with the lighting trimmed then pasted the diddled one over the right out of the poser render adjusted transparancy. There that is all I did. I like the model, there are some minor things with the texture map but all in all it is a great model and I really like the changes in the structure of the body. Now with the new morphs coming along it is going to be a great model.
