Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Technically, ScottA, your example of three point perspective could fall into the two point category. Its kinda hard to tell when there is only one object there, though. Viewing the top of the object simply indicates that the object is below eye level, not necessarily that a third vanishing point was used. (sorry, had to be a smartass ;p) MarlaLP-What exactly were you thinking in terms of a demonstration? Like an animated lecture? Or more along the lines of what ScottA had in mind? Evo
Now that I think about it ScottA, your one point is fine, as long as it is directly centered over your point, same goes with your two and three points, as long as the object is centered between your points. However, your two point could also be a four point if this were the case. (more smartass, I know, sorry ;p) Evo
Maybe it's "pointless".... sorry, couldn't resist... =8^)
On-line
portfolio / Making figurines
in China /
Gallery / Video
Demos
Nukem did a great job of illustrating this assignment. He should get an A+... Using Poser people in a similar scenario may make the illustration more interesting to some observers of your presentation - including the guide lines showing the horizon and convergence points would help explain the issue, perhaps.
On-line
in China /
Gallery / Video
Demos
Hi, Nate. I generated those images soley for MariaLP's benefit and I didn't think to make the images more comprehensive for everyone, so here they are again--- hopefully they'll be a little more helpful. :-)
1-point perspective
2-point perspective
3-point perspective
NOTES: You must have a figure loaded in the scene, otherwise the horizon and vanishing lines won't appear! Nuke
Hey - I'm an art student who is supposed to give a presentation of one, two, and three point perspective. Would it be possible to use Poser to model the different perspectives? If so, how? Thanks -Marla
