Thu, Nov 14, 11:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Poser/Bryce question about a rock
RLG1034 ( ) posted Fri, 25 October 2002 at 7:46 PM ยท edited Thu, 14 November 2024 at 11:46 PM
Not sure if this should go in the Bryce or Poser forum so I'll post it in both and hope for the best. I used the stone creation tool in bryce5 to create a typical stone. I then used the export item command and saved the stone as a wavefront object, (also tried 3ds). Brought the stone into Poser 4 just fine, however when I try to apply a texture to it I get nothing. I can change the color of the stone in the materials editor but I cant apply a texture to it. Any ideas? Thanks for any help.
Little_Dragon ( ) posted Fri, 25 October 2002 at 8:05 PM
It might not have any UV-mapping. I'm not acquainted with Bryce's export options, so I don't know what you can do from that end. Worst-case scenario, you could try running the mesh through UVMapper and using a spherical projection or something.
Raddar ( ) posted Fri, 25 October 2002 at 8:57 PM
Thanks. Got the same answere in the Bryce forum, guess everyone but me thought of the obvious. Oh well nice to have a place to come for help. Thanks again.
weirdass ( ) posted Sat, 26 October 2002 at 1:56 PM
Attached Link: http://www.weirdass.net
Export it with textures FROM Bryce. This will give you a psd map to work with as well.
