Sun, Feb 2, 8:32 AM CST
Forum Moderators: Staff
Subject: Imranshah stuff invisible is Poser 4
punishery2k ( ) posted Mon, 21 October 2002 at 5:42 PM · edited Thu, 30 January 2025 at 2:28 PM
I just downloaded some of the Imranshah's works for Victoria. I correclty installed the clothing in Poser but as I import them into a scene they don't appear. The clotihng is correctly recognized by Poser and, after importing, the object appears in the object's list but it doesn't appear on the screen. I've tried some different items and they all appear to act the same way. Any solution?
kalador ( ) posted Wed, 23 October 2002 at 4:55 PM
Have you tried rendering the scene after you conform the clothing? If I remember correctly, the transparancy sliders were moved to the right in the materials editor when I first downloaded those items, so that the clothing did not show as a solid object when they were loaded, but did once rendered.
Hisminky ( ) posted Sat, 26 October 2002 at 2:04 PM
One of the main problems is that the .obj for each clothing piece is IN the character library folder, NOT the geometry folder. If you changed anything in the unzipping path(unzip in the Poser4 directory) then Poser can't find the .obj.
