Hi dolyl, you'll need this: http://developer.nvidia.com/docs/IO/1176/ATT/msvcr70.dll (copy to windows/system or winnt/system), and this: http://developer.nvidia.com/docs/IO/1176/ATT/dds.8bi (Photoshop Plug-in) for Photoshop support. If you just need to convert them directly into .tga, download this: http://developer.nvidia.com/docs/IO/1176/ATT/DXT_TOOLS_v5.19.zip and use the readdxt.exe. In that final download, you'll also have the Photoshop-Plugin and the .dll needed for it. hope this helps, -Sascha.rb
Attached Link: Texture Study: Cement and Cloth
NV ruined my week-end--didn't do anything else than trying out the textures and smoking lots of cigarettes. ;) I uploaded an example to renderosity (see attached link). WIP, of course--but I might continue with that theme none the less. ta, -Sascha.rbThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Attached Link: http://developer.nvidia.com/view.asp?IO=IO_TTVol_01
Hi there, in its developers-only section (http://developer.nvidia.com), NVIDIA also caters for artists. Checking for some Cg information, I stumbled over an excellent hires-textures pack. The 110MB download is stock-full of mostly tileable 512 and 1024 textures in .dds format, which can be easily converted to something Vue can cope with using the Photoshop-for-Windows plugin (to be found here http://developer.nvidia.com/view.asp?IO=ps_texture_compression_plugin ) and a small batch script. Well, perhaps e-on will directly support .dds in Vue 5? ;) At any rate: well worth the download it you have the bandwidth to spare. I converted the textures into .tga format, and ended up with almost 170 Megabytes of VERY high-detail textures and a couple of very usable bump-maps. Perfect stuff for close-ups in Vue. Usage is completely free, even for professional work; you're just not supposed to print/distribute the textures themselves. Have fun, -Sascha.rb P.S. as .dds, the textures are Windows only. After conversion, of course, they run on Mac as well. -.rb
