Mon, Jan 27, 4:25 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: What's going on here then?
A_Hookey ( ) posted Mon, 28 October 2002 at 9:37 PM · edited Thu, 28 November 2024 at 9:45 AM
I'm trying to apply a bump map to simulate a knurl on a connector cap. See image of shader. I imported a model that was in STL format through Amapi into 3DS and then into Carrara 2.1 . The rendered image shows 3 different models. The model at the rear right is just a standard cylinder created in Carrara - it maps fine. The model in the middle is the STL converted to 3DS (ignoring the fact that for some unkown reason the model is broken down into 2 sections), and it looks as though the the bump map is applied but r-e-a-l-l-y stretched out. I was able to kinda make it looks right in a "final" image but I had to have the texture tiled 30 (!) times. The model in the front left is one I whisked up in Strata Studio Pro just for fun, exported as DXF, and it looks even worse. Any idea why the bump map is not mapping? Thanks, Andrew H.
ppowellaa ( ) posted Tue, 29 October 2002 at 5:15 AM
click on the modeling wrench->edit->convert to other modeler (vertex) In the vertex modeler you may need to tweek/crease some edges if it smoothes them. Select all of the model, in the right pop out panel is a section for uv coordinates, try cylinder. now apply the shader and bump map. Hope that helps.
ahookey ( ) posted Wed, 30 October 2002 at 8:01 PM
Thanks ppowellaa, this did not work so I just ended up remodelling the part anyway! Andrew
