Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Doesn't a square-shaped gel "mask" on a regular spotlight work for this purpose? Haven't tried it, but I would think it would. Look into placing black & white shape gel images on your lights. Failing that, an actual "Barn door" object might serve to control where your shadow lines fall, and if you got really clever, you could build one with moving parts -- four angle-changing blades on the sides, post it to the web, and make a lot of people happy!! ---
Hey who's the model? I like the way it turned out. Those elf ears look similar but a little different to the P4NF one's I posted. It'd be funny if this was Millie...
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
![file_124606.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_124606.jpg)
This is FAR from finished. First I had to figure out just how to get the maps to come over to Carrara. Whew! And then, what a pain to do trans maps on an imported Poser figure. :( I will eventully do a particle emiter for the wil-o-wisp and add plants and a background. BTW, is there a square spotlight anywhere? James
