Sun, Feb 2, 10:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: Help
Hisminky ( ) posted Fri, 01 November 2002 at 12:18 PM ยท edited Sun, 02 February 2025 at 9:55 AM
Insufficent disk to render at current resolution. This error in Poser 4/Propack-current patches. I deleted the poser temp file(which was huge) and the one in p5. Cleared ALL temp folders, rebooted. I still get the error UNLESS I render to main screen. It doesn't matter which size or resolution. I tested it with Render to new screen, size 90x90 72 DPi and I STILL get the error. I didn't get the error UNTIL I installed the latest P5 SR2 Patch. Is ANYONE else with P5 getting this error in P4?
SAMS3D ( ) posted Fri, 01 November 2002 at 1:35 PM
Not me, not at all....Sharen
thgeisel ( ) posted Fri, 01 November 2002 at 1:53 PM
there was something about swapfile, if you dont have poser on a hd than the one your swapfile is on, one should make a second swap on the hd ,where poser sits. its somewhere in the cl faqs
Dagon ( ) posted Fri, 01 November 2002 at 2:00 PM
Attached Link: http://www.curiouslabs.com/article/articleview/211/1/50/
From CL Faq : "Poser 4 Poser can't render high resolution images. Error appears "Insufficient disk space to render" After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater.
To modify the Virtual Memory:
Windows NT 4 = Right Click my computer. Click the performance tab. Click change.
Click the drive Poser is installed on.
Enter 10 in the Initial size field.
Enter 500 or more, in the maximum size field. Click set.
Click OK. Click OK. Click OK.
Restart the System.
Windows 2000 = Right click My computer. Select the Advanced tab.
Click Performance option. Click Change.
Select the drive
Click set. Click OK. Click OK. Click OK.
Restart the System.
Windows XP = Click Start. Right Click My Computer in the menu. Select Properties.
Select the Advanced tab. Click Settings, next to Performance.
Select the advanced tab. Click Change.
Select the drive Poser is installed on.
Click the Custom size button.
Restart the System.
Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution"
Hisminky ( ) posted Fri, 01 November 2002 at 3:55 PM
Trying that now... And crossing my fingers
GROINGRINDER ( ) posted Fri, 01 November 2002 at 9:02 PM
How come you "snork" before you say Renderosity in your yahoogroup email?
Hisminky ( ) posted Fri, 01 November 2002 at 9:31 PM
for the same reason you decided to POST it here.
