Sun, Jan 12, 3:26 AM CST
Subject: P5 WalkDesigner "above ground" question
ablc ( ) posted Fri, 01 November 2002 at 12:37 PM ยท edited Sun, 12 January 2025 at 12:17 AM
Hi, I need to make a char. walking with Yaxis=1, or each time i try to use the WalkD. the charactere reach the ground. Is there a way to modify or correct that except modifying the Y value for each frame ? Thanks Laurent
ScottA ( ) posted Fri, 01 November 2002 at 4:15 PM
Hi Lauren. After you create your walk with the WD. Go to Frame 1 and select the "body" of the figure. Then set the y dial to where you want the figure to be. Then open the animation pallet. Open the graph pallet for the body. And select and drag the line for the body so it's a straight line. That will keep the figure at the same floor height throughout the the entire animation. ScottA
ablc ( ) posted Fri, 01 November 2002 at 4:53 PM
thanks for the tip. Laurent
pack ( ) posted Fri, 01 November 2002 at 7:20 PM
there is a python script for performing a "Drop to Floor" for every frame- This fixes foot both below floor/above floor issues. The script was included w Poser Pro, not sure if w P5 tho
ScottA ( ) posted Fri, 01 November 2002 at 7:39 PM
I forgot all about that script pack. It's included with P5 as well. The one thing I don't like about that is it writes to every key frame. I prefer to use the linear mode and only convert to keyframes if absolutley necessary. But that's just my personal preference. That script is much easier and faster if you don't mind the keyframes. ScottA
