Mon, Dec 2, 5:54 AM CST
Subject: Grouping
josiahpugh ( ) posted Fri, 07 April 2000 at 7:05 AM ยท edited Wed, 06 November 2024 at 1:01 PM
How do I group objects to each other, and make sure that they correspond which each other.
LoboUK ( ) posted Fri, 07 April 2000 at 7:13 AM
I'm not 100% certain what you mean. Do you mean you want to parent one object to another so that when you move one object everything attached to it moves as well? Or do you mean using the grouping tool to create new props/material areas? Paul
josiahpugh ( ) posted Fri, 07 April 2000 at 8:15 AM
I want it so that when I move one object, everything attached moves with it as well.
LoboUK ( ) posted Fri, 07 April 2000 at 8:56 AM
Choose one of the objects to be the main object (the one that you're going to move to move all of the others). Then select each of the other objects you want to move with this and double-click on each one. This will open a window with various options. Select "Parent" and scroll down the list until you find the main object. Click on this, click okay and return to Poser. Do this for each of the objects. Now, when you move the main object, all the parented objects (called "children") will move with it - retaining their relative position. Hope this helps Paul
