Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
From what I've read In the Poser 4 Handbook, Amapi is s nurbs modeler and therefore not good for Poser figure development. Poser doesn't like nurbs (which I think that even the Poser 5 manual mentioned) You could make props with it for Poser, but that would be the extent of it. I purchased Carrara 1 from Eovia so that I could some day (if I ever find the time), design my own 3d figures.
You could use Amapi to create, (what they tell me,) more organic shapes with its NURBS modeler, then import the models into Carrara, convert to vertex models, and then bring into Poser for ... um... posing. After that, export the files back out of Poser, import into Carrara, and use its better rendering engine. Of course, if you're doing animation, then going into Poser is useless, since you can't import Poser animation into Carrara. :< BUT, C has bones, so you can create your animations in C. :> Either way, GOOD LUCK!
Poser 5 has a great rendering engine! It produces ray traced images that look great now, much better than the old P4 engine. As for the animation, Poser does animation well. Using vertex and metaballs you can create realistic organic forms in Carrara. Setting up a poseable figure in Poser then exporting the model again to animate it doesn't make sense to me. If you have the new Poser 5 or Poser 4 with Pro Pack you can bone to your hearts content in the Set Up Room. If you don't have the afforementioned there is a text based method to convert a model into a poseable figure as well, it just takes longer.
Small PS to Brycetech's excellent info above : Amapi (v. 4 and up) will export LWO, which can be converted to OBJ in Anim8or (free), and then imported into Poser 4. Poser Pro Pack and 5 will read LWO directly. Triangles can be "cured" with a detriangulation app - I have seen at least one mentioned here in the Forums, but can't remember its name, sorry.
I own Amapi 5.1 just started to learn it. I have the option of upgrading to either Amapi 6.1 or Carrera 2.1 for the same price. Primarily I'll be building models for use in Poser. Any suggestion on which program to upgrade to would be appreciated. Oh yea, I'm running on a Mac, so Mac specific advice would be most welcome. thanx in advance Jon
