If you dont need very much detail in the feather you can use one of the stock plants that comes with Bryce.. click on the little triangle beside the "Create" menu..and look in the "trees" section monkeying with various textures I was able to get a pretty decent one. Also, i've even seen the leaves off the Bryce palm trees used as a feather backdrop.. if I recall right, it was a sorta Pinup poser scene.
Attached Link: http://www.iaw.on.ca/~jspirko/models2.htm
The only ones I know - never tried them. Hope it helps.Fernando
Attached Link: http://www.renderosity.com/freestuff.ez?Topsectionid=0&Form.SortOrder=UserName&Start=1&Form.Search=
If 2D pic objects are OK, Here's a link to a search for feather in free stuff here. There are several sets of 2D feathers, which you can make into 2D pic objects fairly easily, even map them to flattened spheres to give them an added dimension.This is not my "second childhood". I'm not finished with the first one yet.
Attached Link: http://3dmodelworld.com/obj.asp
Sorry, that link won't work. If interested, you'll have to do your own "search" keyword feather. In the meantime, I found a feather object here. Looks like it might already be a Bryce object, judging by the pic.This is not my "second childhood". I'm not finished with the first one yet.
Does anyone know where I could find a model of a feather? On a somewhat-related note, someone mentioned not being able to find models of small birds a couple days ago, there's one at 3dcafe.
