Fri, Nov 15, 1:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: File size
looksgood ( ) posted Mon, 11 November 2002 at 12:00 PM ยท edited Thu, 14 November 2024 at 11:34 PM
Ok, I have flash mx and I have poser 4. I would realy like to know how to make someone in poser as an animation and add it to flash without loseing the quality of the person and at the same time keep the file size as low as can be? Please help me to make this happen. Remember, file size low and good quality. Thx
ScottA ( ) posted Mon, 11 November 2002 at 12:46 PM
You can't. But of course the whole thing hinges on what you consider a "low file size". Flash uses vector tecnology. Poser uses Pixels. You can't compress vector colors. So the only way to make a small flash file is to use only a few colors. But if you reduce the number of colors of a rendered image to a few colors. It won't look as good. The file size and vector quality is all dependant on your Trace bitmap settings inside Flash. ScottA
EricofSD ( ) posted Mon, 11 November 2002 at 9:27 PM
So that's why my flash animation render/export sucked so bad. Thanks, for some reason I didn't pick up on the vector/pixel thing. And I should have because the two different formats have a way different feel to them.
