Sat, Nov 30, 7:02 PM CST
Subject: Painted on body texture question
wtsmith ( ) posted Tue, 12 November 2002 at 5:05 PM ยท edited Sat, 30 November 2024 at 6:38 PM
How do you keep from getting such ragged lines like the blue one in my sample photo. Ya I know there are body curves and thats why the logo of the dancers distorted. but the blue line looks like I scribbled it on.
SamTherapy ( ) posted Tue, 12 November 2002 at 5:15 PM
If you map the UV template onto the figure, render and print, you will get a much better idea of how the lines fall. I ran into something similar when I drew my Aladdin Sane texture for Mike2.
Phantast ( ) posted Wed, 13 November 2002 at 5:09 AM
But knowing why you get this sort of distortion doesn't make it any easier to fix it. Presumably there is a way of drawing lines crooked on the texture so that they come out straight in the render. But how does one do this?
SamTherapy ( ) posted Wed, 13 November 2002 at 8:12 AM
Phantast, as I said above, map the UV texture onto the body, render the figure, then print it out. You then have a guide to see where the lines fall. After that, it's kinda trial and error - and lots more rendering and printing - until you get it right. If you leave the UV gridlines on the texture until the very last thing, you have a constant guide to work to. Basically, the only way to do it is to actually dive in and do it.
Phantast ( ) posted Fri, 15 November 2002 at 5:45 AM
Well, that's what I mean, really. Trial and error is not a very efficient process. Looking at the example above, I'd have no way of guessing to put in a kink >there< and not there.
