Sat, Feb 15, 11:39 AM CST
Subject: Mask morph for Mike
RawArt ( ) posted Tue, 19 November 2002 at 2:30 PM · edited Sat, 15 February 2025 at 11:26 AM
Anyone know a good morph for Mike to bring his face flat as Spidey's costume calls for? The one I downloaded doesnt seem to really work (as you can see) Or anyone have any other ideas? Rawnrr
Ghostofmacbeth ( ) posted Tue, 19 November 2002 at 2:33 PM
Think there is one for the "Darkness" figure that was in the freestuff here .. not sure who it was by.
JFStan ( ) posted Tue, 19 November 2002 at 2:46 PM
Ghost, I know the morph you're talking about, and it's a good one, but unfortunately you'll get similar results simply because the vertices in Mike's head are shifting position thereby screwing up the texture template. For Spidey's head, you might need to re-map Mike's head with the morph applied. Just a planar front-back map would work in this case. Now I know you're going to ask me how to do this, and I'm going to have to concede to someone with more knowledge in that area. :) Somewhere out there I saw some Spidey masks for free.. That may be the way to go, just add your new texture to one of those. You might want to check out Mosca's Spiderman Symbiote for Mike in Free Stuff as well, perhaps he's already solved the problem. Hope this helps.. -=JFStan=-
atthisstage ( ) posted Tue, 19 November 2002 at 2:51 PM
They're at a animotions, in the prop section.
SAMS3D ( ) posted Tue, 19 November 2002 at 2:56 PM
Can't you just turn his head off and keep his eyes on? Sharen
RawArt ( ) posted Tue, 19 November 2002 at 3:07 PM
I dont really want to use a prop...but it is a good fall back Sharen....How does one "turn his head off"? Rawnrr
sturkwurk ( ) posted Tue, 19 November 2002 at 3:14 PM
In the Movie, Spiderman's mask is more of a helmet then a stocking... so a prop, actually isnt too far from what was really used. Sharby has a great prop available at Animotions. Doug
I came, I rendered, I'm still broke.
SAMS3D ( ) posted Tue, 19 November 2002 at 3:20 PM
Go to the Heiarchy and find head and click the little round thing next to it off, or click on his head, go to objects, then properties, and make it invisible. Sharen
RawArt ( ) posted Tue, 19 November 2002 at 3:45 PM
Thanx Sharen....that is what I thought it would do, make the head invisible. I thought it you meant something which would remove the features. I think I may end up using that mask prop...it is a very nice one. Thanx everyone :)
pdxjims ( ) posted Tue, 19 November 2002 at 4:39 PM
There's a set of superhero face morphs for Mike and Vicky by Traveler over at rDNA in the freestuff. They might do for you. I just downloaded them. They aren't perfect, but the Masked ear is pretty good. No mask for the mouth though. The no nose is a little rough, but with a little post work, it could do.
RawArt ( ) posted Tue, 19 November 2002 at 5:38 PM
The mask worked quite nicely....what do ya think?
SAMS3D ( ) posted Tue, 19 November 2002 at 7:10 PM
Looks great, really great....Sharen
