Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
In Image Ready I can usually save at 60 without problems-- 80 or 75 if I really want to. Check my gallery, I dont' think I have any jpeg pixelation-- except before I learned to used alpha channels on the damned rendered backgrounds. If you need to use 100, you haven't got a very effective jpg maker. IMO. Emily
Rendering with Poser I save with 90%, with PaintShop I use 15 (the inverse 100 - 85%), quality above 90% doesn't make any visual difference, so saving with 100% is a vaste of filesize. The only problem with jpeg is when you have small pictures 200x200 or less like thumbs, here you need to increase the quality to 95-98% for very small sizes and many times gif produce better results.
Stupidity also evolves!
Ok, when I render something and save it as a jpg there are squigle lines and distortions around the figure. How do I get rid of that so that I can keep the good view I made in the render?
