Forum Moderators: Wolfenshire
Photoshop F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
I may be way off base here, but couldn't you separate the Alphas from the images, then just merge the two "Alphas", the same as you merged the two images? You could then put the merged Alpha back with the merged image? Just a thought, I haven't tried it, so I don't know if it will work or not? . . . . . Mark.
Cinema1954: Getting the two alpha into one image is what can't seem to reproduce.
Both images where rendered in Poser and saved in both TIF and PSD (wasn't sure which would work best. The first time I merged the two the alpha's seem to simply merge but when I try to do it again only the first alpha remains and the second is only bringing in the RBG?
I now have the merged RBG but ontop of just one alpha and can't seem to get the second alpha to join it.....???
When I try to copy the second Alpha on top of the first, for some strange reason they just seem to 'Swap'....?
(sorry, can't post the whole image as I'm using it in a current contest but got other things I want to do with it first that could greatly use the merged alphas..)
Try this: Say you have three images, one of which is going to be your background and two of which are foreground elements with alpha channels. We'll call these Background, Foreground1, and Foreground2. In the Foreground1 image, duplicate the one existing layer then select the lower of the two layers. In the Background image, Select - All and Edit - Copy. Back to Foreground1: Edit - Paste. Foreground1 should now have three layers; from the top: A copy of the Foreground1 image, a copy of the Background image, and the original Foreground1 image. Go to the Foreground2 image, Select - All and Edit - Copy. Go back to Foreground1. Click on the top layer, then Edit - Paste. You now have both Foreground images on top of the Background image on top of the original Foreground1 image. Go back to Foreground2. Click the Channels tab, then click the Alpha 1 channel. Select - All and Edit - Copy. Go to the Foreground1 image. Click on the Channels tab. Click on the Create New Channel icon. Edit - Paste. Your Foreground1 image now has 4 layers: Foreground2, Foreground1, Background, and the original Foreground1. It also has 6 channels: RGB, Reg, Green, Blue, Alpha1, and Alpha2. You can close the Background and Foreground2 images; everything is in the Foreground1 image, all registered. You can do whatever you want now. I would suggest rather than blending layers together, you simply cut each of them out by Select - Load Selection - Alpha X, Select - Invert, and Clear. It's also easier to just Select - Load Selection - Alpha1, then Edit - Copy from each image and paste onto your background. The only problem with this is that the pasted images may not be in registration with each other.
Annie
Cinema1954: That makes sense (at work now so it'll have to wait till tonight) The registration should not be an issue here since the origonal Poser is the two background images separated into 2 scense for rendering. I do this since I tend to create scense too big for my system to render so I'll render it as two or more, simply removing charaters untill it renders and then re-opening the originals and remove the other charater and then re-combine in PhotoShop. This is the first time however that I chose to try reasembling the Alpha as well....gonna figure this sucka out yet!
Attached Link: http://www.planetphotoshop.com/tutorials_effects.html
I found the answer! The key is Linking! Found it in a tutorial here: CREATING A MASK OVER MULTIPLE LAYERS http://www.planetphotoshop.com/tutorials_effects.htmlThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I have two rendered images from Poser both saved in PSD. I want to merge them into a single image with a single combined Alpha channel. I thought I had it once but then saw some errors in the combined image and just redid my merging but now only one of the Alpha cannels appears; no longer am I getting the combination of the two....?
