Fri, Jan 24, 10:04 PM CST
Subject: is it true
deadman67 ( ) posted Tue, 19 November 2002 at 3:13 PM ยท edited Tue, 14 January 2025 at 6:03 PM
or am i seeing things i'm a bryce5 & vue4 user i was downloading some vue4 Materials i noticed they are compaible with both programs the file types are the same am i right about this????
gebe ( ) posted Tue, 19 November 2002 at 3:23 PM
No! They have both the extension *.mat. But they are different. Just try:-) Guitta
deadman67 ( ) posted Tue, 19 November 2002 at 3:28 PM
well i downloaded the Materials from the vue section after i went and checked out the files and they are Bryce5 Materials Presets and then i tried them in vue and it seems to work.
gebe ( ) posted Tue, 19 November 2002 at 3:35 PM
MightyPete ( ) posted Tue, 19 November 2002 at 6:12 PM
Ya you got to come back here and explain that one. Cause they don't work. But maybe you discovered a way. Are they single materials or all in a bunch? Maybe they work when there single. Are you sure you didn't download the wrong ones? Where did you get thses materials from?
arry ( ) posted Wed, 20 November 2002 at 4:29 PM
I,ve the same as deadman67 every file in my materials folder is a bryce5 material preset. I have Bryce installed on my pc is it possible somehow that if bryce is installed, files will be allocated to it instead of Vue.
MightyPete ( ) posted Wed, 20 November 2002 at 8:16 PM
Oh you got that problem. Oh that's just a simple icon mix up. That's a microsoft problem in that it allows only one program to share a file extention. Why. Who knows. Fix it by finding the extention in folder options just find the extention .mat and delete it. You don't need a registered extention with a material file. if you double click on a material like ya right the program is going to start up and show you the material like a picture? I don't think so.
nggalai ( ) posted Thu, 21 November 2002 at 9:09 AM
Yup. The problem is that Windows sees .mat, and has the file association ".mat = Bryce material". that's all. Hence, even vue *.mat are labeled "bryce material". ta, .rb
