ok, steaks ar on the grill... Now, I like to change the number if I plan to share the file with others, that way folks do not get that annoying error message about the wrong version #. Now, you will see a bunch of stuff between the "Figure" near the bottom, and the version # near the top. Delete it all. It is fun, my kids laugh at the little beeps...
yeah pam, that's what i do, just cut out from a cr2. :) didn't use cr2 editor though, just text editor, lots of times the cr2 takes too long to load. :/ by the way, this works in poser 5... save as a pose file. unfortunately not able to use it in the new materials library :( materials only change one material at a time! :(
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Many thanks, Pam! I'd been puzzled by the MAT pose because it had been explained only in terms of fancy applications. Your raw-editing explanation worked.... I just now used it, and on the first try succeeded in re-upholstering and repainting a chair! Incidentally, the various CR2 editors don't work well for inanimate objects like furniture because they assume too many "humanoid" properties in the CR2. So I'm thankful when somebody gives a description that can be applied to raw editing.
My python page
My ShareCG freebies
Mat poses seem complex, ockham, but they're really not black magic. They just look that way. ;] ERC and JCM - now THAT's black magic. ;] Seriously, if you collect a lot of them - not hard to do in various freebies and store items - and spend some time dissecting them in WordPad, you start to get a feel for how they're constructed and what makes them tick. That's basically what I did... plus banging my head against the monitor on occassion. Cool tips pam, thanks. ;]
"I am a good person now and it feels... well, pretty much the same as I felt before (except that the headaches have gone away now that I'm not wearing control top pantyhose on my head anymore)"
The easiest way to make a MAT pose file is probably using the free utility MAT Pose Edit. The down side of using MPE is that you don't learn anything about the insides of poser files, and that's why tutorials like Pam's are valuable. The same technique as Pam describes here could also be used with the free CR2Builder utility. As Pam says "Yes, you could also use any text editor...", and this is actually much quicker than using CR2 Editor or CR2Builder (though probably not as quick as using Mat pose edit). If your feeling brave and don't mind getting your hands dirty in a text editor, this is what I do. I start with a template file, like so: { version { number } figure { #---Start MAT Section--- #---End MAT Section--- } } (It's a good idea to write protect your template file, and also the cr2 you will be using, so that there is no chance of them being accidentally damaged.) With this template open in a text editor, I resave it with a new name and a pz3 file extension to a props pallet I open the CR2 in another text editor window, and use the "Find" or "Search" function to search for "canonType", this takes me near to the start of the materials section. I then copy everything down from, and including the first line that starts with the word "material", down to, but NOT including the line that says "displayMode USEPARENT" (this will be one of the very last few lines in the file). I now paste what I copied into the template between the two marker lines, and resave the file. That's it, test your file to make sure it works, and your finished. The lines starting with "#" are just visual markers, Poser will ignore them, and you can leave them out if you want. If the file doesn't work it is usually a case of miss matched braces, there should be an equal number of right and left facing braces in the file. The end of the file should look like this: reflectionStrength 1 } #---End MAT Section--- } } Except the value of " reflectionStrength" may be different. One last and very important point, if you are going to distribute your MAT files you should check all the map references to make sure they do not include a path. This is WRONG: textureMap "C:Poser 4RuntimeTextures01V2AnnaVhedTex.jpg" This is WRONG: textureMap ":Runtime:textures:Poser 4 Textures:AnnaVhedTex.jpg" This is RIGHT: textureMap ":AnnaVhedTex.jpg"
Woo hoo! More MAT pose fun! It hasn't even been a week since the last one. You'd think people just invented MAT poses last week! Is cr2 Editor a free program? You're certainly giving it some good advertsing. I hope it's free or Spike may get after you for advertising in the Poser Forum. You're not allowed to mention marketplace stuff in this forum. Here, I'll beat you to the next topic: Yes, you can use Poser 4 things in Poser 5. No, you can't get Vicky for free- you have to purchase it from Daz. No, fairies are not child porn. You can get the latest Poser 5 patch from CL's website. The patch is free, but you have buy Poser 5 first.
