Tue, Feb 4, 5:01 AM CST
Subject: clothing
kumite ( ) posted Sat, 23 November 2002 at 10:10 AM ยท edited Tue, 04 February 2025 at 4:59 AM
I downloaded a wedding dress from http://iso.power.ne.jp/project/vicky but I can not get it to show up in poser 4. please tell me what I need to do.
galactron22 ( ) posted Sat, 23 November 2002 at 10:59 AM
Attached Link: http://www.curiouslabs.com
you probaly need to upgrade to the poser propack, or poser 4.03 which I belive you can still download for free at the Curious Labs website.
Ask me a question, and I'll give you an answer.
Nance ( ) posted Sat, 23 November 2002 at 11:08 AM
More info needed. How did you install it? Where did you install it? Do you get any error messages? (... and how did I miss ISO & LovelyLady's wedding dress package!!)
galactron22 ( ) posted Sat, 23 November 2002 at 11:14 AM
Well...Download it and run the EXE file (if you're on a PC, install file if youre on MAc)like you would when installing any other Application, and Presto! every thing shold run like it should.
Nance ( ) posted Sat, 23 November 2002 at 11:40 AM
Just grabbed it. No .exe, so if you are on a PC, after unzipping, drag everything in the "/WDDress_pack" folder (a readme and a new /runtime folder) directly into your main Poser directory (the one ABOVE your existing "/Runtime" folder).
It will tell you it already has a Runtime folder and if files have the same name do you want to replace... blah blah blah. Say yes and these new files should all go where they need to be. btw - there are no thumbnail .rsr files, just .png's, so if you are using P4 you will just get ShruggingGuy icons. Open and resave to library to generate new thumbnails.
galactron22 ( ) posted Sat, 23 November 2002 at 11:42 AM
Sorry I thought you were Talking About the poser upgrade, when you use winzip it should give you the option to unzip into folders this usually unzips everything into it's respective folders on the desktop or where evr you send it to. Personally I stopped using Winzip and switched to Stuff it It works with Zip files as well as it's SIT files, bu as far as Zipping files I still Work With WINZIP.
queri ( ) posted Sat, 23 November 2002 at 12:12 PM
Isop's zip paths are incorrect. They begin wrongly-- anything that does not begin with Runtime, begins wrongly. Uzip them to a separate folder outside of Poser and move them by hand. They will be in the correct folders after the cover folders-- just to guide you. Maya Studios does the same with their hair. Emily
kumite ( ) posted Sun, 24 November 2002 at 10:00 AM
Thanks you but I have another part to the question that I posted today.
