Fri, Jan 24, 5:23 AM CST
Subject: 3ds object
thedouf ( ) posted Sat, 23 November 2002 at 5:14 PM ยท edited Fri, 24 January 2025 at 5:23 AM
Hi! guys.............
I have bryce 5 and i have little problem !!!!!
I open a 3d object in Bryce ( it's a castle ) and it's about 40 items to give texture applications........
I just open the same castle in Poser and it's give me just 2 items that i can applicate textures.
I use the grouping tool in Poser but notthing change....
Is there a way to get these items to applicate textures in Poser ??????
Thank's to all.
Thedouf
EricofSD ( ) posted Sat, 23 November 2002 at 5:33 PM
Attached Link: http://www.castironflamingo.com/tutorial/grouper/index.html
A program called Grouper will open your .obj and resave it to what you want. The resaved .obj will be grouped by texture. If you only use two textures, then likely there will only be two mesh's in Bryce to work with.
thedouf ( ) posted Sat, 23 November 2002 at 6:17 PM
i just try Grouper and it's for obj. files.... What i'm talking about is 3ds. file. It's the castle i'm talking about. In Bryce... it give me about 45 items to applicate tex... and in Poser just two ?????? I d'ont know what to do !..... Thank's for all. Thedouf
dan whiteside ( ) posted Sat, 23 November 2002 at 7:41 PM
HI again Thedouf . Ok - Load the 3DS, make sure it's selected and hit the little "E" icon. The Edit Mesh dialog comes up and type Control-D. This brings up a File Selector and at the bottom popup select the .OBJ option and name it with an .OBJ extension. Hit OK and Bryce should save out the object as individual parts.
dan whiteside ( ) posted Sat, 23 November 2002 at 7:47 PM
Now in Poser 4 Load the .OBJ with the Poser Default Import options. Hit the Group Tool and in the Group Edit dialog hit Spawn Props. Close the window and click the down arrow under the main window and under Props select the original import and hit the delete key.
thedouf ( ) posted Sat, 23 November 2002 at 9:24 PM
Thank's a lot...Dan.
It's work..... and i do a nice Wisard Castle with the textures i want.
Thank you very much....
Thedouf.
lsstrout ( ) posted Sun, 24 November 2002 at 10:53 AM
Neat castle Thedouf, please post us a picture when you are finished. Lin
thedouf ( ) posted Sun, 24 November 2002 at 12:15 PM
For sure....I past almost 3 hours to decode all numbers of the parts that gave me Poser... when i import this castle.... Thank's everybody for help.
Thedouf.
Colette1 ( ) posted Sun, 24 November 2002 at 7:59 PM
Very nice castle. I would really like to see your finished work too!
thedouf ( ) posted Sun, 24 November 2002 at 8:18 PM
That's the one i post in Poser gallerie...... But i want to do something special wit all the textures changes....... I'l do soon as possible.... Thedouf.
