Fri, Nov 22, 1:33 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Nver seen this in vue before
dolly ( ) posted Fri, 29 November 2002 at 7:27 AM ยท edited Fri, 02 August 2024 at 2:10 PM
lo all as you can se in the image it is all blue now the cam is inside the building and it has one light the colour is white for light so y is this all blue,any help greatly appreciated cheers dolly
genny ( ) posted Fri, 29 November 2002 at 8:31 AM
Is there a ceiling on the room? I find that this happens to me when there is "No" ceiling and the light is "reflected?" from your sky. genny
dolly ( ) posted Fri, 29 November 2002 at 8:40 AM
lo yer there is a ceiling but i found if i save as pz3 with textures on then this happens, now if i export as obj form poser then import to vue and then apply textures it works out ok strange eh cheers dolly
genny ( ) posted Fri, 29 November 2002 at 8:52 AM
hmmmm.....maybe gebe knows what's going on? (: genny
deadhead ( ) posted Fri, 29 November 2002 at 8:57 AM
This happened to me, when I placed some objects into the sphere. Try this: Check material of your building and in transparency tab set fading to clear (move slider left, i.e. to 0%). This is not editable unless you set transparency to 1% and higher, but then you set transp. back to 0% and you will see. This could help you.
deadhead ( ) posted Fri, 29 November 2002 at 9:00 AM
This is what Im talking about:
YL ( ) posted Fri, 29 November 2002 at 10:55 AM
Could it come from blue fog or haze? Just an idea ;=) Yves
gebe ( ) posted Sat, 30 November 2002 at 5:48 AM
I have the same problem with P3z files. But as soon as I put light, it becomes "normal". :-)Guitta
