Mon, Feb 3, 8:06 PM CST
Subject: P5 renders everything black
WLC ( ) posted Wed, 04 December 2002 at 11:58 AM ยท edited Mon, 03 February 2025 at 7:48 PM
I have Poser 5 it was working perfectly fine then all off the sudden every time i render all the charaters become completelt black. I opened the same file in P4 and its perfect what the problem.
thgeisel ( ) posted Wed, 04 December 2002 at 12:05 PM
Had similar, in my case it had something to do with the lights,had some "black lights" in poser and after deleting them everything rendered as before.
dan whiteside ( ) posted Wed, 04 December 2002 at 1:03 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=910494
Try this thread. Best -Dan
EvoShandor ( ) posted Wed, 04 December 2002 at 1:52 PM
I had this on one of my recent renders in P4, it was because the camera was "inside" the ground plane. this may also happen I guess if its is on a wall or prop. move your camera a bit and try to re-render. or, try it from a different camera. if these don't work....see the "lights" solution above. Evo
Spit ( ) posted Wed, 04 December 2002 at 2:25 PM
With all the new light sets around I've been running into this more and more. I've never quite figured the exact details out, but if a light changes type when switching sets, it goes black. If you have pro pack or Poser 5 it's easy enough to fix with a python script that deletes all the lights. There are a couple available (have to hunt, I don't have links). Only other solution is close and reopen Poser.
