Mon, Feb 17, 6:58 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Opacity Mask - White Halo
chuckerii ( ) posted Mon, 02 December 2002 at 10:17 AM ยท edited Fri, 14 February 2025 at 7:39 AM
Just curious if anyone had found a solution to the white halo that is produced around a texture map when applying a mask.
tkane18 ( ) posted Mon, 02 December 2002 at 10:36 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=288127
Here is a previous post that discusses this. Also, do a search of this forum there are several more posts on this issue.
chuckerii ( ) posted Mon, 02 December 2002 at 10:52 AM
Thanks... I had already read these threads but the only solution that seems to be offered is rendering at a larger size then scaling down. Just curious if anything new had surfaced that I missed on how to solve this white halo problem.
velarde ( ) posted Mon, 02 December 2002 at 11:17 AM
There are several ways to work around but the one that has worked for me is this: (I'm assuming your are trying to place a decal with a rectangular layer into an object) 1) make the Texturemap (save as TIFF)Don't use jpgs or gifs 2) Make an opacity mask (black and white) also save it as TIFF. 3) Apply the texture map as a rectangular layer. 4) In the Transparency channel add a Rectangular layer with the same dimensions as the texture map and place the opacity mask there. I don't remember ir white is invisible or black, but If make it wrong, just check the "invert" option. 5) I think that eliminates 100 to 99 percent of the halo. I hope this helps...
Patrick_210 ( ) posted Mon, 02 December 2002 at 11:33 AM
Here's a shader setup for transmaps that works well. I think Litst posted it on the Yahoo Carrara forum.
chuckerii ( ) posted Mon, 02 December 2002 at 11:41 AM
That's it! That's the one I was searching for in the archives. I guess I better write it down this time before I forget it again. Thanks Patrick...
bluetone ( ) posted Mon, 02 December 2002 at 6:25 PM
The important thing that may not be immediatly noticable, is that you can't use anti-aliasing on the outside edge of your transparency map. It has to be: 1 pixel 100% white, the next pixel 100% black. If there's a grey there, you will get a partial transparency, and that may be the color around your image. In the shader, in the blender part, the 'sampling' filter is used instead of 'gaussian' so that it doesn't blur the edge, which would cause the same problem. By the way, this is also a great way to mak a forest of trees. If you have a clean photo of a tree, make a black/white version of it, and set up the same shader. Then take 2 planes, set them at right angles to each other, and assign the shader to them both. At most angles, you'll see a tree with clear areas between the leaves. Also, set the renderer to 'light through transparency" or you'll end up with strange shadows. Hope this helps!
Kixum ( ) posted Wed, 04 December 2002 at 3:39 PM
There's a few of those trees (positives and blenders) available on the C disks that come with the application. -Kixsupercool.gif
-Kix
