Fri, Jan 24, 1:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Subject: resolution ?
ming ( ) posted Wed, 04 December 2002 at 8:12 AM ยท edited Fri, 24 January 2025 at 1:01 PM
Is 72.000 the max resolution that P4 renders. Thanks
Gort ( ) posted Wed, 04 December 2002 at 5:12 PM
The resolution setting doesn't have anything to do with renders, set the render resolution by setting your window size (choose "New Window" as opposed to "Main Window"). That resolution entry is there for some printers which require it... I don't know what the upper limit is... I make some pretty big renders. :)
Smitthms ( ) posted Thu, 05 December 2002 at 6:06 AM
I render most of Mine @ 1200x1200 in a new window, with the dpi set to 300(instead of the default 72), then postwork & resize & sometimes crop in Photoshop 6. Its way easier to touch up smaller areas in post when the image is clear & not pixelated. Then resizing it smaller, makes the image sharper & crisper. Hope that helps. Thomas
ming ( ) posted Thu, 05 December 2002 at 6:13 AM
Yes it does. Thank you very much.
Smitthms ( ) posted Thu, 05 December 2002 at 6:21 AM
My pleasure. Thomas
