Tue, Jan 7, 9:59 AM CST
Subject: I'm trying for an explosion in water effect.
GROINGRINDER ( ) posted Tue, 03 December 2002 at 11:24 AM · edited Wed, 11 December 2024 at 7:36 PM
Did it work?
catlin_mc ( ) posted Tue, 03 December 2002 at 12:29 PM
It's stunning but I think the ripples should be toned down a bit. They should not be the same texture as the actual explosion. IMHO. Catlin
GROINGRINDER ( ) posted Tue, 03 December 2002 at 12:32 PM
Cool, I was wondering about that.
Aldaron ( ) posted Tue, 03 December 2002 at 2:27 PM
If you have Pearl Harbor or access to it use that as reference. Those bomb splashes are all CGI and are excellent.
Incarnadine ( ) posted Tue, 03 December 2002 at 4:04 PM
Suggestion for the ripples - use the same mat as the regular watter but up the ambience just a tad and set it to blurry edges. Flatten the toroids and place then just a little above the surface but mostly just below. The column of water should be almost a smooth white at the base and feather out as height increases. Try an AB blend heavier transparency at the top. Good luck and let us know how it goes.
Poppi ( ) posted Tue, 03 December 2002 at 6:54 PM
GG...couldn't you just quickly model the shape you want for the water explosion....texture it in bryce, but, use a transmap to make it look more natural...? (after going through your uvmapper tute in rhino forum, looks to be a piece of cake for you, yes?)
Zhann ( ) posted Wed, 04 December 2002 at 12:58 AM
I think the ripples should be the same color as the body of water, an explosion in water would produce a spray in all directions similar to nu-be's but more spiky, IMHO...
Bryce Forum Coordinator....
GROINGRINDER ( ) posted Wed, 04 December 2002 at 1:51 AM
Thanks folks, I appreciate the comments and will try to fix it in the textures, but I am afraid I will have some more modeling to do. @Poppi. I modeled two parts of the explosion in Rhino and two parts in Amorphium Pro. Now I may throw in some metaballs to add the spiky spray, or maybe a terrain. Oh the ripples on the bottom and the splashy part above it were the parts modeled in Rhino.
GROINGRINDER ( ) posted Wed, 04 December 2002 at 5:36 AM
Now I've tweaked the materials, but still want to add the spiky ball thingy that nu-be and Zahn were talking about.
GROINGRINDER ( ) posted Wed, 04 December 2002 at 9:39 AM
Now I've added a spikey cloud.
catlin_mc ( ) posted Wed, 04 December 2002 at 10:13 AM
Stunning and perfect. Great work GG. Catlin
lsstrout ( ) posted Wed, 04 December 2002 at 10:34 AM
The cloud makes a huge difference. Great job. Lin
Incarnadine ( ) posted Wed, 04 December 2002 at 10:39 AM
looking much better, I would still make the ripples closer to the ambience of the main water layer though and use the blurred edges effect. One other point, how deep is the u/w explosion, if very deep (i.e. depth charge)the spray will be concentrated more vertically than you have shown, if near the surface (i.e. shell splash) it will be more radial/spherical. This difference is due to what is driving the gas bubbles, explosive pressure (radial)or buoyancy (vertical) by the time they reach the surface. Again getting there very nicely.
Zhann ( ) posted Wed, 04 December 2002 at 2:23 PM
Great job, and I sgree with Incarnadine, just one more thing, the column in the center should not be so obivious, or should be expanded in width some, just a teeny weeny bit...and you've got it...=)
GROINGRINDER ( ) posted Wed, 04 December 2002 at 2:31 PM
Thanks all I'm still gonna be tweaking on it, but all this transparency is really killer on render time.
Incarnadine ( ) posted Wed, 04 December 2002 at 5:34 PM
I know! But for the final, it should be worth it. My final renders (1280x1024 typical) range from 1 hr to 7 depending on what I have going on in the image. (and that's on a P4 1.8G w/512 RDRAM!)
pauljs75 ( ) posted Fri, 06 December 2002 at 6:01 PM
Shhh... Don't tell anyone that this post inspired me... I made a watery explosion with 2 terrains and 2 spheres. Heheh... ;) L8R!
Barbequed Pixels?
GROINGRINDER ( ) posted Sat, 07 December 2002 at 8:09 AM
Post something for the rest of us to learn from.
pauljs75 ( ) posted Sat, 07 December 2002 at 12:25 PM
Alrighty then... Dunno how much this will help.
Click to see the pic of two terrains and two spheres.
Probably not the worlds best, but a little postwork and it would look good. :)
Barbequed Pixels?
GROINGRINDER ( ) posted Sat, 07 December 2002 at 1:18 PM
Thanks it always helps to see how someone else does something.
