Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Obj format should work o.k. if there are no spaces in any material name or group name, and if every group has a distinct material name (instead of just "default" or "shader x" for everything). Poser 4 will always render worse than Carrara, not much you can do about that except upgrade to Poser 5 and try its snail's pace renderer, using whatever bug fix is current.
I'm having problem importing objects from carrara to poser. The textures get screwed up or render in poor quality. I have tried the obj format and 3Ds or 3DX format... nothing works. As a last resort, I tried to make a uv map (uvmapper) of the carrara's obj and it's unreadable. I'm using Carrara 1.1 & poser 4 pro. Thanks.
