Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
There are hip/gen morphs for all the figures now, I think so mixing is not necessary or maybe advisable. Textures can be tweaked in many many ways. I used an alien texture to augment a Stephanie faerie-- it was a Vicki texture. If I'd wanted to use it on Steff, I would have needed April's Vic 2Steff skin, but I didnt, I just needed the blue freckles, so I moved the texture around in photo shop in a higher layer above my main Steph texture till I had what I wanted. You have much much more variety if you do that. I need to go back and do it for the body. It's an ongoing project. Emily
Hi, You normally can very usually mix morphes from one vicky set to the other if they still share the same .obj (most of the time). You have to mix the textures in an image editor (Paintshop pro or photoshop are very good to handle layers) but you have to beware they have the two pictures have the same size (change it in the editor). There are zillions of tutorial around, but begin here in the tutorial section. Bryce offers more ways of tex combination but it's an adventure of itself to learn how to use it; Good work Pierre
....I've got a few more beginners questions. Such as....can I mix and match various morphs and textures ....like maybe the hip/gen morph from one model (Tiziana by Arduino for example ) and the exceptional high res texture of another all into the Vicki file? I suspect it can be done provided the texture is tweaked a little here and there. And if that is true, is there a tutorial on such tweaking? Might I use Paintshop Pro? Very many thanks to you all! archrendr
