Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 9:33 pm)
Props do not conform. Only characters (which can also be hats and clothes) can do that. Some props are smart props, meaning they go where they're supposed to, fo r instance on the figures head if it's a hat. But that seems not to be the case here. You will have to position it manually and then parent it to the head once it's in place.
A "smart prop" is created when:
Then, the next time you load "prop x" from the library, Poser will remember the parent and load it in the same place as when it was saved.
Ok?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
How do I get a prop (nazi helmet) to conform to micheal when it shows up to the right of the figure list on the bottom of the character window in the object list. It came with the WW2 props for micheal package. The MP40 does the same thing. When adding to the screen it only has one check mark instead of two. But instead of replacing micheal it just wont conform to him. It doesnt even show up on the list of items to conform.
