A few things I forgot to mention. If you don't render at a setting of 64 or higher, the shadows are grainy. I have blurred reflections turned on in these pictures. The pics each took around 2 hrs. to render.
Attached Link: http://www.ict.usc.edu/~jcohen/lightgen/lightgen.html
That is real good information, thanks! There is another venue you can tinker with, there ia a plug-in for HDRShop called LightGen, you take a HDRI image and run the plug-in on it and it will create a text file with X,Y,Z coordinates of 20 or so points of light and their colors. (You can use 10 or even 30 or more) You take this information and create point lights at the specific coordinates, color them accordingly, and ta da! You can then use the HDRI image, converted to a JPG, as a reflection and/or environment map. Example file using the "Kitchen.HDR" image and 10 points for lights. Light0001: Color: 585.219 503.016 474.023 Direction: -0.117328 -0.0871853 0.989259 Light0002: Color: 277.733 239.911 201.376 Direction: -0.297418 -0.952537 -0.0649301 Light0003: Color: 485.126 411.573 368.069 Direction: 0.989031 -0.0936083 0.114262 Light0004: Color: 369.819 349.904 399.072 Direction: -0.53859 0.529147 -0.655686 Light0005: Color: 1892.71 2111.49 2298.06 Direction: -0.486254 -0.338903 -0.80542 Light0006: Color: 502.765 546.356 662.831 Direction: 0.310797 0.512217 -0.800649 Light0007: Color: 3111.94 4187.11 5226.72 Direction: 0.264254 -0.422419 -0.867025 Light0008: Color: 435.536 370.166 321.171 Direction: -0.991839 -0.0464208 0.118743 Light0009: Color: 1249.27 806.41 408.75 Direction: 0.429011 -0.826688 0.364055 Light0010: Color: 397.616 252.073 191.132 Direction: 0.202338 0.914285 0.350916 I have not tried this as yet, so it is just an idea to save rendering time and still get the lights and their colors according to a HDR image. If you give it a try, please post a WIP. I will get some time this weekend and give it a go then. TMGUsed same HDR image but with 5 light points and brighter color(light) Light0001: Color: 16128 14301 14733.2 Direction: 0.306604 -0.273226 0.911779 Light0002: Color: 21693.3 15162.8 9170.07 Direction: 0.505311 -0.840744 -0.194448 Light0003: Color: 15212.3 13964.8 14048.6 Direction: -0.874643 0.081576 0.477855 Light0004: Color: 40054 48283.7 56812.3 Direction: -0.0286202 -0.206325 -0.978065 Light0005: Color: 9697.83 6767.58 5757.49 Direction: 0.674216 0.736104 -0.0598713 I have been tinkering a bit with this, needs to be simplified some. Will keep tinkering with tis and your idea as well. Thanks for sharing your idea on this. :> TMG
The upper image looks much better than the lower one. In the lower one, look at the book spine - it appears to be lit from below. The book cover is wonderful, BTW. It may be a very lo-tech solution, but one can go some way towards faking radiosity just by tweaking the ambient material settings, so that objects are not dependent on diffuse light to show up.
