28 threads found!
mask2 | 4 | 166 | ||
mask2 | 2 | 122 | ||
mask2 | 4 | 31 | ||
mask2 | 3 | 21 | ||
mask2 | 1 | 12 | ||
mask2 | 8 | 187 | ||
mask2 | 1 | 37 | ||
mask2 | 9 | 259 | ||
mask2 | 1 | 52 | ||
mask2 | 46 | 1115 | ||
mask2 | 3 | 65 | ||
mask2 | 3 | 79 | ||
mask2 | 7 | 197 |
68 comments found!
Maybe DAZ3D will finally cancel M4 and declare women can live well enough without men...
and I know the opposite is not true
Thread: Poser can't find textures? | Forum: Poser - OFFICIAL
I had a similar problem with Poser 7 / Pro
it was related to "!" symbols in the folders' names
(search the forum for my posts, it's a thread I started a few days ago)
hope this may be helpful
Thread: Car Paint Revisited 2 | Forum: Poser - OFFICIAL
Thread: Poser Pro - CPU Load [Task Manager] | Forum: Poser - OFFICIAL
Yeah, so I closed my support ticket with a lot appreciation and dropped my question here: that's how I solved the issue
Now You cannot find a single exclamation marks anywhere in my HD
Yes, I should...
...but the last time I had an issue with Runtime folder whose name had an exclamation mark at the beginning
(see one of my last posts here at Rend
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=3278159)
the Smith Micro support was really Micro...
they even complained because I was "one of those users that is working with Non-SM content"
and so I must have had "dozen of runtimes" (I suppose any Poser user does...)
...I solved the problem only thanks to Rend Forum.
Excuse me if I insist, but the screen capture occurred very early in the render
(it was rendering the top left of the image)...
...what I read on the image I posted is that
neither core was really working.
I didn't have 50% CPU load, I really had both cores at 10-20% of total.
They were both loaded but with a very small load.
I mean it seems like Poser Pro is on vacation: it has the whole system available and only using 10-20%
Thread: Freckles Merchant Res | Forum: Poser - OFFICIAL
For reference ONLY:
I found this other thread
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3270502&ebot_calc_page#message_3270502
it provides both a link to FREE Photoshop brushes and a Tutorial
Thanks to user KEPPEL
Thread: Poser7 / Poser 7Pro : a note on Runtime Folder Names | Forum: Poser - OFFICIAL
My mistake, I wanted to subvert the natural order of nature:
I wante a V getting ontop for easier Spotting...
...I will try with
AVictoria4.0
AVictoria4.1
AVictoria4.2
Thread: Poser7 / Poser 7Pro : a note about multiple threads | Forum: Poser - OFFICIAL
Quote - Here's a typical example. Using 4 threads, the top half finished in about 3 minutes, while the bottom half continued to work for 10 more minutes. If I had only 2 threads, the bottom would have taken closer to 20 more minutes.
Thank You!
I see Your point... that's an important addition to the discussion
Quote - I don't understand this as threads is normally expressed per process
well indeed it's strange for me as well, but I have noticed that, since I marked the "render in a separate process", the two core won't work at full capacity:
number of threads = 2 then FFRender.exe gets up to 56% of CPU time
so I changed and
number of threads = 3 then FFRender.exe gets up to 98% of CPU time
if I disable "render in a separate process", then poser.exe is able to take up to 98% with a number of threads = 2
Quote - (runs perfectly well out of the box with Ubuntu Hardy here if the latest Ubuntu-Updates are installed).
Hey thanks for the hint!
in my office I got a couple of friends using Ubuntu, I am asking them if they're willing to share some info on how to install it on my PC !
Thread: M4 at Siggraph? | Forum: Poser - OFFICIAL
