77 threads found!
Tyger_purr | 4 | 65 | ||
Tyger_purr | 11 | 284 |
2,046 comments found!
It might be of interest to note that they did not "remove" rsr support.
They reprogrammed the core of poser and left that function out because it was more trouble than it was worth to redo.
My Homepage - Free stuff and Galleries
Thread: Poser 8 SR3 | Forum: Poser - OFFICIAL
I seem to be unable to import an obj file.
I have reported it to SM but was wondering if anyone else get one to come in?
I'm glad someone else noticed that. I've been wondering why Poser 8 doesn't remember it's last settings only for that tool. If they could fix this, I could remove this toolbar since I rarely use it and now have to keep it open just to select the translate tool every time I open it or another file. This is very annoying.
The keyboard short cut for Translate tool is "t"
Thread: WIP - Landing bay | Forum: Poser - OFFICIAL
sorry, TD brought me on to do some texturing and they are hosting the files for me.
I think it is only right that if they are going to host the files, they should get the traffic.
besides, there are lots of free sci-fi stuff there.
If the security captcha is too troublesome, send me a PM here and I'll send you a direct link to the zip.
the forum had a database crash earlier. It appears to be up now.
Thread: Soccer Field | Forum: Poser - OFFICIAL
Quote - Nice job, TP. I'm playing around with new materials for it. It's hard to get the net to render nicely without resorting to really high render settings.
thanks.
Unfortunatelly i wasn't able to find a better way to make the net without modeling out the whole thing.
For me it wasn't such an issue because my final renders are all set really high.
Quote - Nice Piece! Did you just make it or has it been out a while?
I made it and put it out quite some time ago but it was only on my site, i didn't link from rosity or anything.
regulation half field (put in 2 and turn one around for a full field) includes a goal.
uses poser 5 materials, If your not using poser 5+ you will need to redo the texture for the goal net.
http://tyger.xganon.com/index.php?option=com_content&task=view&id=91&Itemid=30
Thread: What is the point of the figures that are only in Poser 2010? | Forum: Poser - OFFICIAL
Quote - Another point I'd like to make: if one never goes beyond just placing, posing and rendering, than where's the fun in that?
I only recall using morphs in one of the pictures in my gallery.
The fun is in making the story.
Thread: Interesting PP2010, MC6 in mat pose folder works with no figure | Forum: Poser - OFFICIAL
Poser 6 introduced the mc6 file that Poser recognized as a material and knew that it was not necessary to have a figure in the scene. pp2 files are poses and require a figure to be applied.
The ability to rename MAT pose files (pp2) to MC6 and have them work is an intentional "backward compatibility" that was built into P6 (and later)
I did not know you could apply them from the pose directory, but then i moved and renamed all of my MAT pose files to MC6s when P6 came out.
The only disadvantage i have run into is that DAZ Studio has never been able to see or use MC6 files.
Thread: I need someone to test out an OBJ model - anyone willing? | Forum: Poser - OFFICIAL
Quote - Oh lummy, what have I let myself in for? :O)
I have never done any texturing of a model... I wouldn't know where to start!
But I'm exploring the arena and doing some Clay renders now. This was the first one, with typical Poser render artifacts...
texturing is easy, :) it is the UV mapping that most people dread.
what is the poly count?
I am interested in an arena.
Are there any exists? I don't see any doors
are there lights? as in the physical items in the model that produce lights, not poser/DS light sources.
Thread: is there a python script to set force limits | Forum: Poser - OFFICIAL
semidieu at RuntimeDNA has created a python script that does it.
we are testing and refining it.
the Use Limits in the pull down menu will not save into the figure, it only applies to that scene.
Setting the Use Limits in the scene forces all figures dials back to their limits. This could cause poses to change.
That is not such a good options when all i want is a door that stops when all the way open or closed.
Quote - use a pose file for the figure to set the force limits. That way you can not only toggle the forcelimits on but also SET the limits... You would need to set this on each group that you want the limits to apply to.
That solution does not fit my needs.
I am developing products and setting limits and hiding dials as needed. I was hoping to set ForceLimits on the dials while i was preparing the product before i have even saved it to a CR2.
Thread: Will RSR support be added to Poser 8 in an update? | Forum: Poser - OFFICIAL
