We couldn't find any threads matching the specified search criteria.
41 comments found!
You can search for hand poses for the character you want in the marketplace or freebie section, or you can pose the bones of the hand yourself. Most preset hand poses will need some fine-tuning to fit your needs correctly.
Thread: You Should Use These 5 Steps For Good Topology | Forum: 3D Modeling
Thread: Good Topology Workflows | Forum: 3D Modeling
Thread: Useful tutorial | Forum: DAZ|Studio
Thread: importing models into DazStudio | Forum: DAZ|Studio
Thread: LilFlame ComfyDays longshirt deforce issue | Forum: DAZ|Studio
Thread: jpg of G8f and G8.1f | Forum: DAZ|Studio
If I understand correctly what your issue is try this. I had this happen when I installed a freebie, it change my default setting and once I found the culprit I uninstalled it and it fix my problem. . Load your figure and with it selected got to the parameters tabs: select actor: then people: and scroll down the list looking for anything that's not 0%. In your case this item looks to be set to 100% once you find it set it to 0% and that should clear your problem. If you don't uninstall it will have to be re-accomplished every-time you load your item. If it's not there then you'll have to go through each list under actor tab until you find it. Good luck.
Thread: Animals & Creatures Contest Winners | Forum: DAZ|Studio
Thread: Braided Hair for Genesis 8 and 8.1 Females | Forum: Freestuff
Thread: Easy Color Change Tutorial - Daz | Forum: DAZ|Studio
Thread: Beta testing clothing product help | Forum: DAZ|Studio
I understand that doing renders is not testing a product, I meant I would be doing daz work the next few days. Never mind something came up anyway. Good Luck
Are they dforce? I plan to do some renders in the next few days let me know and I will give them a try
Thread: Swimsuit Poses for Genesis 3! | Forum: Freestuff
Thread: New Freebies: Whiskey Props and SkeleKey Earrings | Forum: Freestuff
Thread: Background color and load a background picture | Forum: DAZ|Studio
Backgrounds are under the environment tab and if you are getting checkerboard pattern then it's set to none by default. Select image in environment tab and then browse to location of image you want or select color white I think is the default.
Thread: How to do hand poses in Daz Studio? | Forum: DAZ|Studio
