DAZ|Studio F.A.Q (Last Updated: 2024 Oct 05 2:10 pm)
Or go to Create -> New Primitive and select pane. Afterwards you have to rotate and move it and then select the Surfacing/Rendering Tab, use the editor and select plane > Default > Diffuse and when you click on that little triangle on theleft side of the Diffuse Color you can browse to the iage you want for your background.
Ulli
In the Environment tab it will be set to "None" click on that you have choices you can add an image by clicking the little arrow dropdown under "Background" or you can click between the RGB numbers on the color bar and the color picker will open up to select your color. In my current setup the environment pane it is on top right.
Background option
Use Background image - Browse
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
HI: I have Daz 4.9 and had 4.8 and in neither of them was a way I could see to change Background color and/or load a background picture. Daz's tuts are all based on older versions of Studio where under the edit drop down, there was a "Change background" selection. That is no longer there. Could you tell me how to do this or point me to a more recent tut? Thanks, Sherrie
