7 threads found!
Cazcie | 1 | 64 | ||
Cazcie | 13 | 204 | ||
Cazcie | 2 | 14 | ||
Cazcie | 0 | 9 |
(none)
Cazcie | 4 | 24 | ||
Cazcie | 1 | 28 | ||
Cazcie | 4 | 28 |
27 comments found!
What if what you want to purchase cost 5 dollars more than what you have for your instore credit? How could that be worked out? Cazcie
Thread: Uvmapper help please multimaps | Forum: Poser - OFFICIAL
thanks alot...I think I did it...when I get the texture map done I will post what I have done
ooftah...I will try my best to follow these instructions..but if I can't get it..I will post an image of the kind of map I am looking for. I appriciate your help.
OKey I got a hiccup. I wanted to split the head and the body of the lion for two maps. No problem....except that the head and body were both defined in materials as fur. So I split them furhead, furbody. Saved obj, saved map opened poser bring in new obj and the body is missing. The tail, claws, and head were all there but the body is missing...cannot be seen at all. So, by this I assume that I cannot split materials? Or did I go about it the wrong way? Do I need to take the entire map both head and body and assign a body group before I can split materials? Does any of this make sense? Cazcie
Well you could reverse it to get a single map. however it would be unuseable as the head would overlay the body. They would not be on seperate parts of the same images.
well if you follow the directions given by Valander up above, you will realize that by doing this you are essentialy saving the same map x 2 for one object...so you only have to save one obj file. Then redirect the cr2 to that object and save it as (ie renaming it) Because your not loading two maps....only one...but saving two maps....if you do that..and then close and reload the object...you will see that the map created has both of your remaps overlaying each other. Hope that makes sense.
but what if I am remapping the whole thing...making the map completely different....I do that first and then make seprate maps? what about when I resize parts of the map will that effect the obj? or just the map? Does this make sense? Cuz I know if I just remap and not save an object then the map wont work. So I guess I am just confussed on saving the object..if I make two maps Ihave to save two objs?
Oh..by the way....I suppose I should explain that what I am trying to do is map the head of a lion seprate from the body of the lion ...same with the panther.
Thread: Renderosity time set for 30 minutes...? | Forum: Community Center
Thread: What is Renderosity's official policy on plagiarism? | Forum: Community Center
Yahoo is reporting that the Project Illusions page does not exist. Either he took it down voluntarily, seems unlikely, or Yahoo got wind of his actions and took it down for him, seems more likely. Cazcie
I got an auto responce back from Julius at Teshan, he will not be back in the office until the 11th. Oh well. I will reaffirm the site and the images then, if they are still on his site and still being claimed by Shin Gouki I will rewrite anew message to Julius. I think it is important as I believe a publisher has some stake into whether an image they published is violating copywrite laws.
all you have to do is go to Shin Gouki's aka Richard Michauds site and see that the same image posted there is now created by Shinya. (recently changed from Shin Gouki after being caught)
You also may want to investigate this user Project Illusion as it appears that this person is Richard Michaud as well as Shin Gouki being Richard Michaud.
Thread: Use of store credit... | Forum: MarketPlace Customers
