1 threads found!
DVcreator | 2 | 11 |
70 comments found!
Hey , whats your clip rate 24/second, why not bump it up to 30/sec or 36/sec, And then render.
it should shorten the run time, Or maybe re-edit in a editing program, Cinema4,
R
Thread: waterfall? | Forum: Vue
what are you looking for Niagara Falls, Angel Falls, Or a low cascade through and over rocks?
how about mixing rock and fast rough water material on a 'rock' and rotate it to the veritcal against a landscape feature...
R
Thread: Amsterdam Amsterdam... | Forum: Vue
Ya, here in about a month ago, LWO I think , file was 'little buildings', they are pretty good for european facades...
hope it helps
R
Thread: quick question - i'm ashamed | Forum: Vue
Generally state what version of Vue your using helps, And thats what this forum is here for asking Q's. In the backroom (lookup at the header) there are plenty of tutorials I have found very helpful...
Okay so you want to put a different top on a (cube) building, most of the models have a (+) symbol in the right side viewer, this will expand to individual components of the object. click a highlight on a component and change its texture.
And play with some of the free models in the FreeStuff ....
hope it helps
R
Thread: books on vue (esprit?) | Forum: Vue
Why not a source guide, 1 part Key guide, 1part workShop book, 1part advanced techniques, 1 part challenge of inventiveness...
Publish as a PDF with the purchaser given 2-5 licenses to print a hard copy.
Save on distribution and production costs,
And would be released on an honour system thought community forums.
thats just my initial idea
R
Thread: * * * Vue Challenge - now voting * * * | Forum: Vue
Thread: Need advice on building a new system | Forum: Vue
Checkout   ALIENWARE.COM or, DELL.COM they have detailed schemes for graphics with detailed hardware, cards, and product id numbers, then you take this info to a local trusted computer shop that will service your glitches when they happen, this will save you hundreds...
Or Check out CGTALK, for advertizers. Â I might even look at the new BOOTSTRAPPED APPLE, with the dual Ops system...
Ask freiends
R
Thread: Vue 4 Interface Problem | Forum: Vue
Thread: Easel>VUE 4 file exchange? | Forum: Vue
Thread: * * * Vue Challenge - now voting... * * * | Forum: Vue
Thread: Running VUE directly from CD... | Forum: Vue
What about a USB Drive, as the installed drive and try it with a scene ready to modify. it will probably be slower because of bus size. tell us if it works.
Thread: Security Camara effect | Forum: Vue
photoshop has filters to get the effect, for a still, i remember, i think, Cinema4 has a 'Filter' for post work on a movie/video...R
Thread: * * * January - February Challenge - now voting * * * | Forum: Vue
Thread: Theforce.net is dead ? | Forum: Vue
I just pulled it up fine through Google.ca, and broadband in canada...the Great white North has the Force...
Thread: I've got XStream curiosity | Forum: Vue
I saw a couple of comparisions at 3DCG.com , or 3dgi.com , about a month ago, sorry it was from a string in this forum. Hey, The east end of lake ontario isn't that cold today its 5'c...R
Thread: Compressing a video file | Forum: Vue
