5 threads found!
Dave Wight | 0 | 10 |
(none)
Dave Wight | 3 | 27 | ||
Dave Wight | 6 | 45 | ||
Dave Wight | 6 | 70 | ||
Dave Wight | 13 | 126 |
2000 Apr 21 10:23 PM
22 comments found!
It may not be your problem, but I've found (I think...) that the Mac requires the initial colon (:runtime:geometries:...), whereas the PC doesn't.
Thread: UVMapper | Forum: Poser - OFFICIAL
I think you need to delete (or rename, to be on the safe side) the big rsr file in the same directory as the obj file. Poser only uses the obj file to create the rsr, which it then uses to speed things up.
Thread: Too many files! What to do? | Forum: Poser - OFFICIAL
Thread: Poser to LightWave | Forum: Poser Technical
Many morph targets are distributed with points only. This saves file size and also protects copyrights. Most of the Victoria morphs are like this, otherwise you could collect enough morphs, glue them back together, and get Vic for free. You'll need to apply the morph to the actual figure, export it, and use that file.
Thread: Dumb questions | Forum: Poser Technical
Try changing the name to whatever.obj; if that doesn't work, it may be a zip or sit file, change the name to whatever.zip and see if you can unzip it (with stuffit).
Thread: O.K. now I've done it...help | Forum: Poser - OFFICIAL
In the prefs folder is Poser.ini. In it you will find a line that says: USE_META_UI 1 Actually, yours probably is set to 0, change it to 1 & you'll be back to normal, whatever that is.
Thread: Need info about OBJ format | Forum: Poser - OFFICIAL
Thread: Files With "max" extension | Forum: Poser - OFFICIAL
Thread: Physics 101 | Forum: Animation
You might take a look at this: http://www.servtech.com/public/wkimler/humor/cartoon/cartoon.html
Thread: Amd or Intel?? | Forum: Poser - OFFICIAL
Thread: List Of Contributed Softgoods to the Store for Donation | Forum: Community Center
I'll volunteer to do these. 1) a collection of lawn furniture 2) camping equipment (including the canoe & tent) Maybe I'll tackle the Jetski later.
Thread: an idea please read jack and everyone | Forum: Community Center
I'm in. Can we have some kind of request line or sign up sheet for people volunteering for a particular object? And maybe a request list.
Thread: Newbie FAQ? | Forum: Poser - OFFICIAL
Thread: Anyone know how to get a obj file from a 3dsmax file? | Forum: Poser - OFFICIAL
Thread: poasble telephone wanted | Forum: Poser - OFFICIAL
Thread: Help with missing obj's!!! | Forum: Poser Technical
