We couldn't find any threads matching the specified search criteria.
11 comments found!
Thanks for the information. Just catching up with my Renderosity surfing now that I have some free time. Any Who, I just tried Batch Queue for the first time after reading all the information.
In the Task Manager > Physical Memory Available Regains after a short time as before with some really large settings it would drop tell Carrara would stop with the "memory allocation" Long story gets Longer:
Carrara 7.2 render Setting
Batch Queue Render, Full Raytracing no DOF, AA Good, Object Accuracy 0.5, Shadow Accuracy 1, Photon Count 30000, Photon map Accuracy 30%, Light Quality Good, Accuracy 4.
Output
11" X 17" at 300 dpi, pixel Aspect Ratio 1.00 File Format PNG. Alpha Channel, Premultiplied Alpha.
Those setting before would give me a "memory allocation" in Batch Queue the Status is showing Completed 5 hours and the minutes.
I know Carrara 7.2 can do the Scene at lower render settings and the same PNG format settings. Here is the rub, After Batch Queue is finished I have a PNG File of 33bytes it should be around 7 MB finished. Carrara and Photoshop fail to recognize it.
Did I skip something for Batch Queue ?
Did I miss a Memo?
I’m trying it again but the output File Format is Photoshop.
"Thanks all For you time"
Thread: help with animation bryce 6 | Forum: Bryce
O yes I used Mimic 3 Lite. Glad you like it :) Be for I forget when you go from DAZ Studio into Bryce 6 at the end of the import you are on the last Key frame of the animation. Before changing anything in Bryce put the animation on the first Key Frame. DAZ has a Key Framing Plugin for Studio that I didn’t have at the time. It should take Poser Out of the work flow. I Have not had time to play with Animator yet but what I did check out looked good.
Have a good Weekend
You might like this, keyed in Poser 6 exported and cleaned up in DAZ studio and rendered in Bryce 6
Thread: Brycetech Tutorials? | Forum: Bryce
Ok I was reading the thread and scratching my head. It’s been a few day from the first post but I was checking and http://brycetech.com/ is up and running and http://brycetech.daz3d.com/. http://www.brycetech.com/tutorials.html is a no go. I would not like to see anything happen to Brycetech Tutorials. I think thy should be required reading I learned more on those Tutorials then and of the written stuff that I got with Bryce.
Thread: depth of field | Forum: Bryce
Adding some more input to the knowledgeable ones above me.
I just put some quick on together. Rays Per Pixel effect the quality and render time. Lens Radius will also play into quality. It looks to me any thing over .50 starts to get destroyed. A setting of 10 will obliterate all except for Object selected. The rays per pixel set at 4 render time was 8 seconds. The rays per pixel set at 256 render time was up to 8:43 minutes and that was with ground material not casting shadows.
Resetting the numbers by typing in the box the number you would like. If you changed the lens Radius to ".15" "decimal point Fifteen" and didn’t get the decimal point the Lens Radius is way high "15" " fifteen" that would make everything blurry.
If a object "A" is to be in focus and Object "C" is to be out of focus this would be True.
If object "A" Is closer to the camera and you would like to include Object "B" too the In Focus. If object "B" is Farther away from the camera Than Object "A" Bryce will Give you a Average Focal length of the two Objects. Bryce will attempt to focal length on the space between "A"and "B" Giving a "False" Focal Length. The only way I can think that the work around would be is if Bryce had a Start and End Focal length.
You can always try Depth of Field Generator Pro by Richard Rosen man and Martin Vicanek . It will give a lot more control over the depth of field. http://www.dofpro.com/index.htm
Thread: P7 and AO strange lines | Forum: Poser - OFFICIAL
You can only see them in the shadow areas? It’s the hole render in my monitor. Les noticeable outside the Shadow areas. I would get bucket lines some times in P6 AO or not. EF never gave a answer other than something is wrong with my PC?
Can You reproduce the effect at a different bucket size. And what are the Specifications of your computer.
Thread: V4 vs Sydney Challenge | Forum: Poser - OFFICIAL
Thread: E-Frontier Announces Poser 7! | Forum: Poser - OFFICIAL
You didn’t see the "If Thy fail to produce I will Move on." "If Thy" being the Key words to a comprehensive paragraph subject mater. The paragraph structure is on. Me not
understanding
"Purchase to Support Theory." When I’m a Firm Believer "Build it and thy will come."
The other Part "Render" of the post Is what I think thy would have to do to convince me to Pre-order
not just words.
The Part on Sydney that’s just funny
and The "Can’t Produce" I only see C and P no Big E or small F
just remember I have not said anything about price.
If that is the only thing you can come back with after I take my time to show interest in your work. That’s just inconsiderate. Well thank you. You only look at small trivial things and not the big picture.
Correct one person, but fall in line with the lemming. Have a nice day.
I look forward to seeing your Poser 7 work. I beat it will new, Exclusive and Extensive art work
Hi All Have you been to th CP Forum On Poser 7. If you haven’t take a look. Thy a getting blasted. Ef has created a special character, Called the "Educated Consumer" for about every 10 "I well what and see". there is 1 "I ordered" standing in the crowed. What? Did I read that right. If I wont Poser developed I should purchase 7. That’s like a Rock Star or Raper saying "I would still be on top but nobody supported me by purchasing my albums and I’m a superstar". "No" people didn’t get you albums because you failed to produce. Or a Actor /Actress Saying "nobody supported by going to my last move and I cant get a acting job". "NO" you last two moves are bad and you failed to produce. Development money comes from investors. I’m a End User. Have a Product that works. If Thy fail to produce I will Move on. I will Shed no tear for the Company or Failed Product or the Investors that lost money.
Well we still have 6 more to go as of this date. When thy get to the render capabilities. "If"
Thy better do more than show a render and make a claims like NEW, Exclusive, Extensive Updates. I hope thy know to have statistics On the render. Poly count, Number Vert, show a wire frame. Multiple shots of the same seen. And render time.
And What is up with Sydney chin? Who did the pre-production sketch? Sid and Marty Croft
O I forgot you have to get the Poser figures Manga Studio Comparable.
See ya all over at Can’t Produce
Thread: Some Rendering Tips I Found (C7) | Forum: Carrara
