2 threads found!
Estgil | 7 | 174 | ||
Estgil | 4 | 111 |
10 comments found!
I am not 100% certain, but I think you can try to select your camera, then go to Attributes and adjust FOV.
Thread: soft shadow no go | Forum: Bryce
Make sure that you close Skylab by clicking on the checkmark (accept changes), not on the cross (discard changes).
Thread: Interested in comments and/or suggestions | Forum: Bryce
Thank you very much!
Yes, the hand is made out of metaballs, and if the light would fall on it from the front a little bit more (fortunately, it doesn't), you would see I didn't use too many of them.
Speaking of lights; may be it's a stupid question, but when light is set to infinite light, visible object: surface; are objects in light's path supposed to cast shadows? There is a source of bluish light in the closet, and I expected to have some shadows on the ceiling, but it didn't work.
Actually, I can't say the process of the making of all this was as complex as it was time consuming. The lamp was made from booleans, the chest - from few booleans, few terrain meshes and several hundred rivets, i.e. spheres (multireplicate tool comes very handy at times, doesn't it?), the plate with cookies - terrain meshes and booleans. The walls and ceiling - boxes, the floor - ground plane, the stairs are made out of a rotated terrain (the image for the terrain made in Bryce, too - mask render of a multireplicated box) Perhaps it's not too difficult as long as the original is close :)
Thread: Bryce Forum's May Challenge Voting!!! - "The Duel" - Vote Here!!! | Forum: Bryce
I wish it would be possible to vote for several runner-ups. Too many great works here. My vote goes to Aldaron.
Thread: May Challenge "The Duel": The Gladiators - First Blood! | Forum: Bryce
WOW!!! When I looked at it, at first I couldn't believe it was made in Bryce. It is SO AMAZING.
Thread: May Challenge Entry | Forum: Bryce
Thread: Entry for May challenge: Chess Game - E.T. vs. A.I. | Forum: Bryce
Thread: May's Bryce Forum Challenge Theme Announcement!!!!!!!! | Forum: Bryce
Thank you very much for the suggestion! Is it OK if I will delete this picture and then put the enhanced one here instead?
Thread: 180 spherical angle images | Forum: Bryce
