1 threads found!
Fluxeon | 19 | 357 |
8 comments found!
Thanks for your help. Come to think of it I have seen mirror effects in Poser I can't remember where though and from what I remember it was sort of faked... you know.. it's not crucial that I have this effect... Because in the day the building reflects mostly the sky.. and on the bottom reflecting part I can just take a render and mirror it in photoshop and put it on the building.. I won't be reflected as I walk up.. but that's ok... heheh... Brian
Thread: Reflective Windows | Forum: Poser - OFFICIAL
If it is possiblee and I figure out from someone how to do it.. I'll make a tutorial... because it would be really great to complete this.. and this is the one obstacle in my way.. from making it look realistic... Brian
Attached Link: http://home.cfl.rr.com/usrey
If I set the reflective map to one side of a cube... will I be able to see through it on the other side? BrianThread: Reflective Windows | Forum: Poser - OFFICIAL
no.. I'm working with poser 4. I was messing with the material properties under the render tab. Hmmm... No easy way.. I know in other programs you can have a two sided "square" like 2d box and set opposite sides to different properties.. but... no such luck in poser. It's getting pretty complicated and I'm wondering if I should just abort creating this office building in poser and use a different program? Brian I'll IM you...
aha.. ok.. so what i'm doing is taking the standard poser box and I'm going split box in the UVmapper to create a UV map. Then on one side I'm going to create a reflective surface.. and on the other side create a near clear surface... and of course squash it to a window width and size.. am I going about this right? Brian
